I followed the Steve Neal style extensive tempo ( built up to 4x30) this winter and had my best performances and highest FTP so far this past spring.
Yeah, Neal’s style of tempo (HR-capped) will make appearances in my longer riding. I’m seeing my EF rise and decoupling come down in my longest rides, so I’m going to start adding time in the hills which will amount to AeT riding and then eventually Tempo in relatively large doses coming up in the fall. Really good training when there’s no racing around, but can also be highly fatiguing when combined with other work.
Part of the challenge with my personal training is I’m trying to push a large increase in volume (from 8-10h/wk to 12-18h/wk) alongside continuing to train with some intensity, and trying to do that without falling apart. So I’m erring on the side of keeping things easy (lots of time in low-to-mid Z2) until I’m better adapted to the duration in the saddle.
I’m always suspicious of ‘magic sounding’ prescriptions - that I need to find the lactate balance point and then somehow use that to do HR capping with tempo.
It sounds vaguely like what I discovered (2016-2017) works for me - low cadence climbing - and what my coach calls Muscle Tension Intervals (search “FasCat MTI” and it should be first result).
Six weeks ago I did 4 hours of low cadence (mid 60s) climbing at ridiculously low power, around .56 or .58 IF with torque around what I usually do on 2 hour endurance Tuesday. Despite similar torque, my HR was upper zone1 and a full 14bpm lower than 2 hour Tuesday. Within 10 days saw adaptations that have slowly increased.
This week I did 2.5 hours of low cadence climbing (66rpm average) at a higher zone2 power, roughly .7 IF. My HR was firmly in my personal upper zone2, same as 2 hour Tuesday, but torque was what I would see if doing 90% FTP at 85rpm.
Experience shows that this type of work delivers repeatable adaptations for me. Might not work for you. Loose HR cap at top of my HR-zone2, honestly its just keeping it aerobic and low cadence. Pretty easy to do that solo on long 4-6% climbs, but climbing at 2W/kg makes them slow climbs so harder to do in a group and they are Strava ego busters putting me at the bottom of leaderboards.
This is part of building my base to do 3 hours of upper tempo in early 2023. I’m betting this type of base work - endurance climbing - will help me fight aging declines and post some personal bests in 2023.
I’m sure aerobic low cadence climbing might sound like the ‘magic prescription’ I described above ha ha, but seriously all it requires is a heart rate monitor, cadence sensor, and power meter. And a little digging into efforts at endurance, tempo, threshold, and over threshold.
Back to WKO - this type of training is off the PDC model’s radar as far as I know. One thing I do is have torque displayed for quick review after all rides. And low-intensity training adaptations - I get better results from doing a Kolie Moore Aerobic TIS moving average on my Garmin aerobic scores than I do on my WKO Aerobic TIS scores (even when PDC is well fed). So I log Garmin aerobic/anaerobic after every ride using TrainingPeaks’ metrics (Abdomen inches and Glute inches), and then modified the Aerobic TIS chart to use these instead.
Hope that helps somebody experiment and find out if it works (or not) for you.
i’m not sure what YOUR definition of “extensive progression” is here, but it’s not how either Tim Cusick or Kolie Moore are using the term in their videos/pods, its not how WKO is breaking down, and its not how I was referencing it.
Their delienation seems to be that Extensive ends up being more SST, intensive is working right around your FTP wattage.
Regarding your comment of;
There’s not in terms of adaption, but there is in terms of fatigue. Hence my earlier comment, and KM’s Watt Doc #39 commentary about working more at the “extensive” level, rather than trying to push right at threshold. You simply can do MORE work, for longer, with LESS fatigue and required recovery. When you put this into the context that the biggest driver of growth is consistency and volume, being able to do more and recover from it is going to help you out more in the long run.
Now…I will caveat all of this with you need to eventually do some specific work, especially if you are doing TT’s and need to be able to ride at or near threshold, but in an overall training plan that is a relatively small % of your overall workouts that occurs closer to your races.
edit:
I will leave the link to the KM watts doc #39 I referenced above. It’s a worthwhile listen and goes into detail why “riding at threshold” can really be a bit of a knife edge excercise.
No.
Per the optimized interval chart this is the breakdown:
I guess Kurt could have extensive mean whatever he wants, but its not how anyone else seems to be using it.
Yeah you guys have looped around all of it. My take:
Extensive means at or below threshold extending TIZ. Power or zone target then spells out how much time you aim for and how aggressive your progression is. You can do just about anything “extensively”… what we are talking about is extensive threshold or extensive sweet spot. Either way, extending TTE is the goal of extensive work.
Intensive means working at powers above threshold for necessarily shorter time periods. This could be 4x8s or 5x5s or it could be over/unders … it could be a lot of things. The focus is not extending TIZ; it’s doing more power.
As I interpret things, WKO shows extensive being at or below threshold - you look at the power it suggests and the zones and it says “FTP”.
@RONDAL I listen to Kolie’s podcasts usually multiple times. I recall in the most recent discussion about extensive work and why 2x20 isn’t enough, he specifically mentioned doing extensive threshold progressions, and also mentioned “or sweet spot if you’re one of those guys” (paraphrasing). My understanding of his extensive work is 95-97% extending interval time out to 55-60min total (or more!) and then evaluating what comes next for the athlete. Often he will see an FTP increase during that time for newer athletes, and that will reset TTE to start a new extensive progression.
He also specifically mentioned using sweet spot during racing season as it incurs less fatigue and allows you to maintain TTE without incurring as much fatigue when doing hard race or race prep efforts as well.
I don’t intend to put words in anyone’s mouth with this stuff, that’s my interpretation.
I’ve done extensive sweet spot progressions the last two years and I think they work. I have NOT done as much extensive threshold progression work (at 95-100%) in my past.
My long work is generally low power right now, and I like the balance of working a bit harder on my hard days by progressing at threshold. Thus far, I’m recovering well and responding to the training.
One consideration for others is how much time you have. Some people can’t ride 2hrs during the week, which makes a 3x30 at 90% a non-starter if they’re also doing long stuff on the weekend.
As I started adding more AeT or tempo work to my long rides, I may drop back to a SST progression to manage fatigue. We’ll see. It may be that I don’t need to do that. I’ve got a good feel for my threshold and I’m not yet feeling cooked from conservatively pushing threshold TIZ while more aggressively pushing overall saddle time.
So, I’m not trying to line up with Tim or Kolie. I do take what they say and learn from it because of everyone out there, I think they really know what they’re doing… but I’m not trying to be either one of those guys. I also don’t think I’m misinterpreting what they say, but I could be wrong about that.
Re: low cadence work, there are a lot of different takes on it, from people who prescribe it every single week at varying intensity to those who eschew it almost entirely (KM would be one from what I have read and heard). I have low cadence tempo planned in my next block… so we’ll see.
Kolie’s aerobic and anaerobic impulse charts are brilliant, IMHO, particularly useful with long history of training to look at.
I’m a fan of stuff that works. For whatever reason, low cadence climbing works for me and produces results ![]()
I am spending a lot more time at <80rpm than in past years, largely because torque generation is a weakness of mine, whereas leg speed is generally a strength.
For many of my athletes, leg speed is more limiting, so I focus on speed work for them. I do a lot of leg speed stuff in my warmups with the occasional ramp or spin up session as well.
have you thought about addressing this through strength work in the gym?
Of course I have, I lift twice a week. Raw strength isn’t much of an issue. I have in my past repped front squats at 255 and a 405 deadlift at 155lbs. My riding style has always been higher cadence. I don’t have much need to generate large torque… it’s a weakness, not a limiter.
Nice.
Strength aside might also want to look at some explosive work in gym if you’re doing it already to supplement bike.
Any jumping, box jump, drop jumps, etc will help the bike work.
It’s not a limiter for me. I’ll worry more about it when it is.
Unlike slow climbing on a mountain bike, on the road I would think that torque generation isn’t an issue for many. Except perhaps sprinting, but that’s more about having a strong PCr energy system and some fast glycolytic energy.
During winter base training it only takes me 3-4 weeks to get comfortable extending my useable cadence range from 50rpm to 95rpm.
That and actually being able to coordinate the movement. It’s always interesting watching some people try to sprint and just the lack of coordination to do it. Similar to a golf swing.
exactly.
My sprint is decent for a skinny 45 year old. I’m not planning to win bunch sprints, but I have snap and good enough peak power to hold my own in Cat 2/3 bunch sprints against younger guys. Hence I’m not worried about the strength/torque… I do strength train, but any low cadence stuff is more about power though a complete circle, muscular endurance, etc.
My low cadence training, when done long enough, say 2-4 hours in a session about once a month, usually results in improved efficiency factor within 2 weeks. Probably some other stuff too but that one I can clearly measure. No idea why it works, just know that there has been and continues to be a clear dose/response.
