WKO5 is here and it looks... different
Haha, I like that - totally makes sense and good to know that decreasing power is somewhat expected. Thanks!
I think the targets/durations from WKO5 confused me, but maybe I’ll ignore them until I’ve completed this initial set of testing to feed the model. Haven’t done any all-out efforts over 5 min so far, so hopefully will develop a feel for how hard I can go for that time.
Anything longer than 3 minutes should be paced as more of an even effort. It’s only the short efforts that should be done with an all out start and then just hang on.
Once you get through these initial max efforts, about every 4 weeks look at the power duration curve vs WKO5’s model of your power duration curve, and you want to target where the modeled PDC is most divergent (higher) than your actual PDC.
Basically you are trying to make sure that WKO5’s modeled PDC best fits your actual PDC.
And just like this week, when filling in the PDC always go longest to shortest
Thanks for clarifying, that’s how I did understand it as well. For the longer ones I’m more comfortable having some idea for pacing.
From my understanding of Cusick’s tutorial, that’s pretty much how the duration/watt targets are derived in WKO5. Makes sense.
The initial structured testing Cusick showed was 5 min, 20 min, 1 min - are you saying 20-5-1?
Looking at my first set of max efforts, they were done in this order:
  • 1 minute
  • 5 minutes
  • 20 minutes
  • 30 seconds
But after the first week, it was longer to shorter
I usually look at WKO5 @ 90 days.
I keep my eye on the model and feed it now and then. I don’t do a set 2-3 days of feeding though that might be good the first time around. It’s pretty easy to throw a 5 second to 3 minute interval into any training ride when the model needs it.
I often ignore the model’s request for long duration efforts. For example, it currently wants 55 minutes at 90% of FTP. I just don’t want to do that.
Every 4-6 weeks I’ll do a Kolie Moore longer FTP test and the WKO5 model seems to like that.
For me, the model is always looking for shorter - less than 2 minute - intervals. And since I’m trying to only feed with inside workouts, really sucks. For whatever reason, I find it easier outside to do really hard short intervals. But since all of my structured work is inside on the trainer, I’m try to primarily build my PDC model inside.
There are a lot of ways to skin that cat. I will have my athletes do a test week to get the initial numbers, then I like to do short tests at the end of a recovery week and hold the longer test until they’ve got a workout in their legs so they’re not stale. I had all kinds of issues trying to FTP test during recovery weeks, and I’ve found a lot of people experience the same thing.
But I can hammer out short and sprint tests after recovery and some opener efforts pretty well. So essentially you get all the curve feeding done once every four weeks, but don’t have to muddle up too many workouts to get there.
For the test week, I do 5-1-20-sprint. I think that’s what Tim recommends in his webinar. But reason I do that is the same as above - I’m stale for long efforts if I do those first.
JMO.
Go find a slightly longer than 1min KOM hill near you and just go test on that. Ones that get steeper as you go i find easiest because it forces you to keep the power on. We have a local uphill TT hill that I use that runs up to a public dog park.
Always fun to go do an effort, get to the top and start dry heaving and feel like im going to cough up blood while karen is out taking her yorkie for a walk
I just did a 2:30 test a few weeks back on a hill like this near my house. Took the KOM from a club mate who was literally on a plane flying to move back to Japan at the time I did it. :open_mouth::grimacing:
But set a slew of all time power PRs doing it so it worked.
Nice!!
I’m excited for that testing week - have 2 weeks with lots of travel and little riding ahead, but then will get after it.
What time frame are y’all looking at for PDC / mFTP?
Noticed earlier that my last week mFTP is much higher (331 vs 316) than my current year mFTP.
From Cusick’s videos, sounds like you should retest every 30-90 days, so it’s that also the time frame to evaluate the PDC for?
Side Q: Can I make charts depend on each other? I’d love to use the gearing chart (bar chart of rear gear on the workout view) as selector for a power and cadence distribution chart of when I was in that gear. I’ve done this manually now, where I just hard code the gear I want to look at, but obviously fun to optimize :slight_smile: thanks!
Is Black Friday/Cyber Monday the only time they have a discount? I’d like to buy the software and don’t want to wait until then, thinking I may just bite the bullet and pay the full price.
I believe that mFTP in the upper right hand corner is the 90 day. The mFTP line on the Power Duration Model chart will change as you change the time range.
I test with the Kolie Moore baseline test, look at the results, then usually go with the mFTP. I’ll set my FTP to that until the next test.
I just did a VO2 mini block and got a 9 watt mFTP bump but I won’t fiddle with my FTP until the next test.
Does anyone know how to create a smart segment using the combination of two laps?
There is a local climb that has multiple segments - bottom, top, total climb - depending upon how you ride it. I did it this past weekend, and I used the lap button for both the bottom part and top part. I created smart segments for both of those. Now I’d like to create the smart segment for the full climb, and I cannot figure out how to do that
The easiest solution is likely using the timestamps for beginning and end (you already have those), and create a new Workout Range:
and then right-click and make it a smart segment.
Thanks. That worked really well, and was really simple. I don’t know why TrainingPeaks makes it soooooo inflexible to create smart segment.
I’ve only thought of doing it from a time range, seemed pretty simply to me. Strava doesn’t let you combine segments, neither does WKO. Having created many private segments in Strava, I find WKO to be easier.
I wish I could more easily create smart segments by:
  • grouping two or more laps - highlight all of the laps, and then just be able to click “create segments” from laps X, X+1, etc.
  • selecting the start and end points on the map. I’ve tried this, and it is really cumbersome. I should be able to view the map, click a point, user the cursors to fine tune the point, and then click “set segment start”. And then do the same to “set segment end”. And then just create segment.
sure, software is so malleable it is easy to imagine a lot of new features. The reason I’ve only thought of doing it from a time range is because that’s the only thing that works :wink: I’ve been in product marketing/management and can dream up all kinds of improvements… Then there is my non-techie wife, she wants every Windows and iOS app to do things the way she thinks it should be done. Which makes her hold most app developers in contempt, because they don’t think like she does, and it seems to generate a lot of daily frustration. My lot in life is remembering at least one way of doing things, even though I haven’t used Windows in 10 years, so that I can reduce her frustration and keep her blood pressure in check :rofl:
