TR account settings: "The Value 99.0 is not valid for weight"
Any idea what I am doing wrong?
Are you located in a country like Germany or so where the decimal delimiter is a comma, not a period?
Yes, but it doesn’t matter what I enter “99,0” , “99” or “99.0”, the form immediately converts any input to “99.0”. And when pressing “update information” I get that error.
I tried switching to imperial units and enter the weight in lbs, but got the same result.
I’d say something at TR is broken.
I see. In that case, I’d contact support. As a workaround you could enter 98.9 or 99.1. Does that work?
If you lose 100g you can try 98.9, see if that works! :smiley:
99 is imaginary weight, nobody weights that. If your weight is 100+ and you decide to loose some units to get your weight to two figure reading, this might work for second but it will never settle to 99.
Facing the same issue right now while updating my profile to be “public”
71.0 do not work
71,0 neither
71.1 nope
71,1 nope
I weigh 27371 gummy bears.
I always use my Zwift weight which is 47kg :slight_smile:
@edoBNC, are you still having issues with this?
Checked right now, still there
Same for me, still doesn’t work.
Can you please set me to 98Kg?
Sorry, I am on a diet. I’ll have to ask you every few days until someone fixes it :slight_smile:
If you have the TR mobile app you can adjust the weight in the app and the homepage will sync. Is your system language different from your browser settings?
Thank you, that indeed works.
Hey @Slowwithouttwitch, I just sent you an email asking for some more info with the hopes of being able to figure this one out. Take a look when you can!
Thanks for your help. :handshake:
Just mailed you back the info…
Had this issue in Jan 25, managed to change values in mobile app, but it does look strange.
I have the same issue of not being able to change my weight. In the account page it says 0.00. On Career it is still at 73.
