New user FTP - possible improvements
Hi folks!!!
I have just completed the rump test on TR–> 183 :crazy_face: .
I’m 31 yo, back on the bike basically after two year stop after my daughter’s birth. Now despite business trips and busy daily routine I had to find a way to re start pedalling, I missed it too much.
I felt to need some sort of guidance and method to better optimize my training, considering that I don’t have much time, and TR seems to be the best option around :grinning::grinning:
I’m starting with a low volume customized plan.
I’d like your opinion about the effective improvements that are reachable with TR consideting my starting point; 2 years ago I was a decent amateur with FTP around 300w for 71Kg, now I find myself at 183W for 79Kg …a bit depressing but the motivation is high.
Using mostly TR do you guys think it is possible to go back to my previous shape??
I think it is very doable to get back to where you were if you make the commitment and are consistent. I had a similar situation, but 50 years old, and did my first ramp test almost exactly one year ago(7/26/23) with a 227 FTP result. Followed TR plan through the end of last year and have had a coach since the start of this year as I am doing Leadville 100. Just did a final 20 minute FTP test last week resulting is 325 FTP (343 avg watts for 20 minutes) at 79kg. This is also higher than my FTP 10 years ago when I was racing. The success I attribute to being very consistent with following the plan with 12+ hours riding each week. Having history of riding I think has also helped.
Absolutely.
TR plans will give you a nice system of progressive overload, the key part I would guess is the consistency in your different lifestyle now.
Be realistic on the time you have to train, and the time you have to recover, and enjoy whatever gains you see.
Thanks for your inputs!!
Now I’m starting with low volume following TR suggestions as I have really not trained almost st all for two years…this would means around 5hrs / week on TR…I would like to combine at least one outside road per week.
Until two years ago I was around 8hrs-10/week only outiside (200-300kms), but without any precise training plan… I was just full gas all the time :rofl:
I hope I’ll be able to put in place a similar progress! Sound impressive!!
For real improvement, the keys are putting three things into your training (in this order!!!):
  1. Consistency
  2. Volume
  3. Appropriate amounts of intensity
Too much intensity without the right volume and you’ll burn out. Anything you do inconsistently will fail to produce desired results.
As noted above, be realistic about what kind of volume you can realistically do. Make SURE you are always recovering appropriately from your training (and other) stress. Then add volume, with appropriate amounts of intensity, and enjoy whatever gains you see.
Just think back to two years ago when you walked around with a 4.23 Watts/Kg FTP. I presume that took some serious training and effort.
Hey there and welcome to the TR community!
I think it sounds like you’re on the right track here with a Low Volume plan given the time you have available to train at the moment.
See how this volume feels for you for a bit, and stick with it! Consistency will be key in gaining your fitness back after being away from training for a couple of years.
I definitely think getting back to where you were is doable. It will help that you have some training history already! Some of that fitness tends to come back quickly once we get back into the swing of things. :muscle:
Glad to hear the motivation is high. Stick to your plan as much as you can, and over time, you’ll start to see those gains you’re looking for. Feel free to let us know if you have any additional questions!
Hey TR world!
I Just wanted to update my situation after 4 months of TR.
As I mentioned in the initial post I started with a FTP of 183W x 79Kg.
As of November, the AI FTP detection tells me I now have 251W ftp x 74Kg
I’m targeting 300W x 70Kg by the beginning of next summer, I hope I can make it…
I have changed my TR custom plan from low to high volume. Do you have any recommendations in regards of what type of plan I should ask TR for to maximize FTP increase (without specific races targets yet)?
Thaanks!
I would not recommend going from low to high volume.
  1. Go from low to medium volume
  2. Make SURE you’re adapted to the additional load
  3. Add endurance volume (low- to mid-Z2, not high Z2) in addition to what the plan asks for
  4. Make SURE you’re adapted to the additional load!
  5. And THEN… maybe… you go to high-volume plans.
Increasing your volume too aggressively has a very, VERY high probability of leading to a gradual but eventual burnout that takes a long time to recover from. Ask me how I know. And see how often that story is repeated around here.
