So measuring TTE seems fairly obvious: take your power at FTP and see how long you can hold it. In general, expect anywhere from 40-59:59 mins. Is there anything more to it than that? How do you determine “holding it”? A power drop of some sort?
Hypothetically, if I want to “spitball it” because I might not want to measure it in the way I just described, any rules of thumb or guidelines? I realize one answer is “TTE is a metric that WKO4 models for you, so you don’t have to this or that…etc.”, so if the answer is “just use WKO4 or Golden Cheetah”, fine. But we get at FTP (more or less) without needing the software to model it for us, can we do the same with fatigue resistance?
Tim
(edit: yes, i’ve read the TP articles and seen Tim Cusick’s video presentation)
Totally agree. Very helpful answer, so thanks @GilbertsGrapes. I’m heading up and to the right compared to some previous timeframes (using SeasonMatch etc).
What I’m trying to do right now is base some sub-threshold (tempo, SS, and even Threshold) interval lengths off of TTE rather than A) just doing what TR says (not that that’s bad, just think I can get more individualized and extend them more…target intensities are fine), or B) using my intuition.
Sounds like what I need to do is do at least an initial progression test. From that point I should just be able to progress them by using recent efforts. I do a similar thing with FTP. I don’t do the ramp test too often (even though it’s fine and fairly non-invasive). I can usually adjust my FTP based on recently workouts (Lamarck, etc).
i want to do next week this test.
i thought to start with the baseline test
Empirical Cycling FTP Tests
BASELINE TEST, 35-45 MINUTES OR TTE
10 minutes at 92-95 percent of target FTP
Increase to 100 percent of target FTP for 15 minutes
10-15 minutes gradual power increase until exhaustion
My TrainerRoad indoor FTP is 311 (outdoor i feel like to be able few watts more).
The WKO5 trail version estimate my FTP around 325, but i did not pushed a all-out effort the last weeks so far.
My Question:
Should i take something between as my target FTP 317 .
starting with 92-95% for 10‘
go for 15 minutes with my target FTP
than i try to gradual power increase until exhaustion 10-15min. correct?
Can you show us you test and the WKO Result after your test?
maybe i get a better picture if i see your graph.
if you cut away all jargon, then you can ride to the point when either your energy is depleted, your power is depleted or your motivation is depleted. Can you predict those? Yes, although you can over complicate things, and ignoring environmental conditions then you can estimate your power at any duration from power at any known duration or time at any future power (FFT Magic Power-Duration Curve (FTP) Predictor [Link: fft.tips/curve] - Google Sheets), you can do the same with energy (FFT Bonking Risk Calculator [link: fft.tips/bonk] - Google Sheets). Motivation is however very hard to predict and model!
Sorry to drag up an old thread @GilbertsGrapes, but i am getting my head around creating Extensive Aerobic intervals from my WKO PD curve, and this thread was helpful, but raised a question
If you use the Optimized Intervals recommendation of say 97% of PD at TTE, at what point does the PDcurve get pushed out by performing by holding 100% of current TTE for longer?
Is the normalized residuals long target often past TTE to achieve this?
And your TTE also changes when you add short power efforts to your curve (of course we are talking only about WKO pdc). Usually when I target my short efforts (below 5 min) and the curv goes up, my TTE shortens along with stamina. So then you have to add these longer efforts to show that you are capable of doing them.
That was what I thought, so I was confused re how TTE could in fact be extended if I was doing intervals at a % reduction of the PD curve at or near TTE. I suppose in time as the durations of TIZ in intervals extend well beyond TTE, the average power will end up higher than than the PDC at that point given the accelerated drop off in the PDC.
I just did the baseline testing of 5, 20, 1 minutes and sprint. FRC and mFTP both moved up a reasonable amount, and as you said TTE reduced back to a paltry 33 mins, hence the initial focus being on extending that out to a useful number
Reinforcing what has been said, and it should be obvious now, WKO isn’t going to predict your TTE. Rather it is just giving a number based on the (90-day) PDC. Don’t feed really short power max efforts for 90-days and your TTE will increase as the model decays at the left side of the power curve. For example I recently had some hard 1-5 second efforts fall outside the 90-day window:
This. So basically 35-45 is little different than 55-60 TTE to give your body proper stimulus. With 60 min tte doing 40 minutes TiZ threshold can be not sufficent. But I do not know what is other application TTE can have (other than measure of your overall fitness)
What does the accuracy of the power measurement have to do with it? Isn’t all that matters is that the demand (running speed or power) is held constant?
My point was that you don’t have to even measure power to determine TTE - just put somebody on a treadmill or stationary bike at a fixed intensity and see how long they last.
Again, I think you’re barking up the wrong tree. TTE is TTE at a particular intensity. It seems to be a common way for sports scientists to measure exercise performance.
For example, just picking at random here’s a study that measured TTE @ ~90% of VO2max…the subjects only lasted 8-9 minutes.
IOW, the TTE that you’re interested in seems to be TTE @ FTP. (Is that too many TLAs for one sentence? LOL!)
On TTE, I continue to remain convinced by the concept of TTE, but doubtful of its practical application for the amateur athlete.
You’re basically asking how long you can hold your Maximal Lactate Steady State power. And unless you’ve measured that in a lab, then everything is to some extent guesswork. Including - perhaps especially including - WKO.
Say your TTE increases. Has it increased? Or is your old FTP now 97% of FTP and you can therefore hold that power for longer? Or was your old FTP an overestimate? Or are your shorter duration efforts on the PDC sub-maximal, as @bbarrera discovered? Or maybe you HAVE increased your TTE. Who really knows?
Or if you do a longer intervals session - let’s say you complete 3x20 at threshold. Does WKO pick that up (genuine question)? Does it see those intervals and recognise that your TTE is probably 45+ minutes at that power? Or does it only spring into action if you knuckle down and actually do 45 minutes all at once?
For example, there plenty of stationary bikes out there that don’t measure power, but simply allow you to pedal at level ‘X’. As long as ‘X’ is the same each time, you could see how variable your TTE @ ‘X’ is from one day to the next.
It’s exactly the same for a runner running on a treadmill, so there is no reason to think that TTE is any more (or less) variable in one sport vs. another.
That’s not what you said at first. So I was confused by what you meant. Anyway, no worries.
As far as your second point, if you’ve set it at level X you’ve fixed the power. So you DO know what it is. It’s not in watts, it’s an arbitrary value, but you still know it. It’s X. My only point ( and I think it’s yours too) is that X+1 gives you a different “duration until I fall over”.
