Does Stretching Make You Faster, Heat, Bodyweight Training and More – Ask a Cycling Coach 352
Coach Chad, Amber, Nate, and Jonathan take a deep dive into stretching, if it makes you faster, how you should do it, and more in Episode 351 of the Ask a Cycling Coach Podcast. Tune in for this and discussions on heat training, bodyweight vs. weighted strength training and much more!
Tune in Thursday at 8:00am Pacific!
Youtube Live Video:
Topics Covered in This Episode
  • Deep Dive on Stretching
  • Rapid Fire / Live Questions
  • How to heat train at various budgets
  • How to drink and eat during interval workouts and not miss a beat
  • Is bodyweight training a substitute for barbell training?
RESOURCES MENTIONED IN THIS EPISODE
Dynamic stretching is not detrimental to neuromechanical and sensorimotor performance of ankle plantarflexors
Effects of Tissue Flossing and Dynamic Stretching on Hamstring Muscles Function
Static and Dynamic Quadriceps Stretching Exercises in Patients With Patellofemoral Pain: A Randomized Controlled Trial
Influence of chronic stretching on muscle performance: Systematic review
Acute Effects of Dynamic Stretching on Mechanical Properties Result From both Muscle-Tendon Stretching and Muscle Warm-Up
The Case for Retiring Flexibility as a Major Component of Physical Fitness
Strength Training Versus Stretching for Improving Range of Motion: A Systematic Review and Meta-Analysis
Effect of the flexibility training performed immediately before resistance training on muscle hypertrophy, maximum strength and flexibility
Acute effects of muscle stretching on physical performance, range of motion, and injury incidence in healthy active individuals: A systematic review
Acute Effects of Foam Rolling, Static Stretching, and Dynamic Stretching During Warm-Ups on Muscular Flexibility and Strength in Young Adults
Foam Rolling as a Recovery Tool after an Intense Bout of Physical Activity
Effects of 6-Week Static Stretching of Knee Extensors on Flexibility, Muscle Strength, Jump Performance, and Muscle Endurance
A systematic review and meta-analysis of the effects of foam rolling on range of motion, recovery and markers of athletic performance
Chronic Stretching and Voluntary Muscle Force
Total Training Volume and Muscle Soreness Parameters Performing Agonist or Antagonist Foam Rolling between Sets
Non-local Acute Passive Stretching Effects on Range of Motion in Healthy Adults: A Systematic Review with Meta-analysis
Effects of Static Stretching on Energy Cost and Running Endurance Performance
The effects of dynamic stretching on the passive properties of the muscle-tendon unit
No Effect of Muscle Stretching within a Full, Dynamic Warm-up on Athletic Performance
Different volumes and intensities of static stretching affect the range of motion and muscle force output in well-trained subjects
TrainerRoad Podcast Network
Submit your Question to the Ask a Cycling Coach Podcast
Subscribe to the Ask a Cycling Coach Podcast
Subscribe to the Successful Athletes Podcast
Submit your story to the Successful Athletes Podcast
Subscribe to the Science of Getting Faster Podcast
Submit a topic to the Science of Getting Faster Podcast
Hurrah! Stretching and flexibility. :slight_smile:
They talked about the updated TRI plans…
Do we have to delete and re-add them on our calendars? Or should it work automatically with already running plans? :slight_smile:
Delete and re-apply with your same initial start date. Sorry for the confusion!
I’ve never stretched prior/after any activities (skiing, skateboarding, basketball, running and now cycling) over my entire life. I’ll give this a listen and see if stretching will bring on the gainz!
What’s changed on Tri plans? Not had chance to listen yet?
Recovery weeks are a bit less volume
And he ditched the brick runs related to that lower volume, if I heard right.
Er… just updated during my recovery week and I’ve been scheduled a Breakthrough Tempo workout! :face_with_spiral_eyes:
Screenshot_20220224-220700_TrainerRoad
Is that to be expected???
Related to the bodyweight strength training, I have been doing single leg work like the pistol squats, split squats and lunges. I got to a point where I have somewhat maxed out with those and my own weight.
Last night I added a small hip pack with a 5lb weight placed in it to do my full routine. Seems like a small amount, but that little weight made a real difference on those exercises. I also added a handheld 5lb in addition to the weight pack for the split squat and lunges (not the pistol squats). I even considered a filled hydropack from my MTB setup (for adjustable weight), but the hip pack and 5lb weight works really to add mass but not alter my range of motion for the movements.
The result last night was notably more load on my body and really bumped up the work without having to get into bigger weights. Feeling real DOMS this morning backs up the higher efforts from last night. I may end up with a regular add of 10lbs at this rate, but may limit to that over time and just maintain at that point.
This work is far more than I’ve done in the past and I am nearing what I think are my needs for general body fitness and improvements to my BMX & MTB racing needs.
Pistol squats (all way down) are SO hard! I can happily squat 75kg (about same as my bodyweight) with a barbell but can’t do one pistol squat without holding door for balance - I just fall over!!! :joy:
  • TRUTH!
I have generally decent balance, but it took me a while to get consistent with them. Even now, I still end up on the floor at least once or twice a session when I get a bit off kilter at the bottom. But I can hit them pretty well now with all the practice.
I am working on repeat efforts on the same leg without touching the elevated foot between drops. I can hit 4 in a row consistently now. It’s honestly a skill that I am kind of proud to have improved on in it’s own right :stuck_out_tongue:
But I can also tell that I am stronger from all the work behind it, so the main goal is working as intended too :+1:
I am naturally very loose. I can easily put my hands on the floor, and touch my foot (either one) to my nose. I work more to maintain muscle for joint stability.
Thought this would be a fun question to ask after today’s podcast. And as a disclaimer, this in no way is supposed to mean you should be able to or it’s a performance benefit. :stuck_out_tongue:
  • Can You Do Full Splits?
  • No
  • Yes (either side to side OR forward and backward)
  • Yes, both ways
0 voters
Just listened to the Pod.
Two things. Attacking when someone is drinking on the MTB is a great idea. I’ve never had the opportunity/need, but I’ve boxed myself drinking up steep single track climbs and I can see how effective it’d be
Second, this should be a good starting point for the planning for @Nate_Pearson @ambermalika and @chad doing some gravel racing pre Triathlon. Attacking through the aid stations (because you carried your fuel/hydration with you) is a great way to gain an advantage, and possibly wind up some gravel snobs/gatekeepers :joy:.
I have never considered that stretching makes you faster but if you run at all it’s all but essential - every time I have been injured running it’s mostly been due to a lack of range of motion…never believed all this rubbish about don’t stretch… :black_cat:…does it religiously in my house and she’s much more agile than me :grinning:
The bodyweight training discussion reminded me of this video:
We can indeed get pretty strong from nothing but our own body weight!
A good time for mobility/ stretching/ or whatever is at night when you’re watching tv with the family. If that’s what you do, anyways that’s what I do. It’s pretty much a routine I stick to every night, even the cats join on the fun. I take about 10 minutes and hit my hip flexors, ankles back or whatever is giving me some discomfort. Whether it makes me faster or not doesn’t matter because it feels good on my body.
Much respect @mcneese.chad - impressive!
I don’t think I can lower more than 15% on a pistol squat. Maybe in my next life.
Enjoyed the podcast - I very much appreciated Nate’s comments about the portion of the user base I most identify with – someone who wants to get faster to have more fun – to stay fit, beat personal bests, test limits, have adventures, keep up with my friends, not be so spent that I can’t be a productive member of my family. Looking forward to the more content mentioned in the future on athletes with those goals!
