Triathlon is already a complex sport, what with the demand for being adept at three different endurance disciplines rolled into a single-day event. But when you add the further complexity of the numerous distances around which all three disciplines revolve, well…things get really complex.
It becomes a wonder how any multisport athlete manages to focus on any other aspect of life should they choose to train consistently for events that have you in the water, on the bike & then running several times a week, every week.
So it was our goal to streamline this process as much as possible within the scope of a cycling-based software company.
We realize that a vast segment of our subscribers are triathletes and while we haven’t gone to the fullest extent by handling all of your training guidance, we’ve refined our approach and stretched our focus beyond just making you faster on the bike to also giving you some direction in terms of scheduling your run & swim workouts.
Triathlon Demands & Training
A simple demonstration of the differing demands between the numerous course distances is the disparity in the swim, bike & run challenges of a sprint triathlon versus those of a half-distance tri. During the former, you’re race is done & dusted before you’re halfway into the bike leg of the latter.
Add to this the objectives of building true fitness in 3 different endurance sports – some more technically challenging than others – but doing so in ways that task the different energy systems in slightly to noticeably different ways, inflict different strains on your bones, muscles & mind – again, even the generalities are a lot to keep up with.
So it’s plain to see that the type of conditioning necessary to excel in one distance isn’t necessarily the kind you’d need for another. And while overlaps do exist, the differences in the training and the necessary time commitments within the very same sport present an interesting challenge for athletes & coaches alike whether you’re just looking to finish or excel come event day.
Consequently, our newly developed Specialty training blocks separately address each of the 4 triathlon distances: sprint, Olympic, half-distance & full-distance.
Specialty Block Structure
We recommend that riders precede most of these blocks with a Sustained Power Build (Olympic, Half & Full Distance) but the General Build block could be an equally good fit for Sprint & Olympic-distance triathletes.
Ideally, these Build blocks would be preceded by 6-12 weeks of Traditional or Sweet Spot Base training, but this is dependent upon your planning and the amount of time available prior to your event date(s).
Following your Base/Build conditioning, the first 6 weeks of these 8-week Specialty blocks focus primarily on addressing the particular type of endurance you’ll need based on the distance in which you’ll compete.
They’re structured in the traditional 3:1 format where you build fitness for 3 weeks and then absorb that training during the fourth week. Then, you’ll start to taper your training during the seventh week before tapering a bit further in your 8th & final week just prior to your event.
As each plan progresses toward your peak, highly event-specific brick workouts and race simulations are woven into your training, more frequently should based on the volume option you select, i.e. low, mid or high-volume.
Block Progression
Optimally, riders will reach their Triathlon specialty block with recent base & build conditioning completed. In this case, here are some likely training periodization structures:
- 28 Weeks Out: 12 weeks of Sweet Spot or Traditional base conditioning + 8 weeks of Sustained Power build conditioning + 8 weeks of Half Distance Triathlon specialization
- 22 Weeks Out: 6 weeks of Sweet Spot Base I + 8 weeks of the General Power Build + 8 weeks of Sprint Distance specialization
- 14 Weeks Out: 6 weeks of Sweet Spot Base II + 8 weeks of the Olympic Distance Triathlon specialty block
Additional Block Progressions
As the race distances grow longer, it’s common to see triathletes target a single, A-priority event toward which they work for an entire season. But for riders with multiple peak periods, here are a couple alternate suggestions:
- Already Fit, 2 Peaks, 21 Weeks Total: 8 weeks of Half-Distance Triathlon + 3 weeks of racing + 2 weeks of Traditional Base I + Latter 4 weeks of the Half-Distance Triathlon block + 4 weeks of racing
- Early Season/Late Season, 50 Weeks Total:
- Early Season: 12 Weeks of Traditional Base conditioning + 8 weeks of Sustained Power Build + 8 weeks of Half Distance Triathlon specialization + 2 weeks of racing
- Late Season: 8 weeks of Sweet Spot Base II + 8 weeks of Olympic Distance Triathlon + 4 weeks of racing
Whichever scheduling route you choose to take, whichever plan progression accommodates your event dates, whichever distance or event distanc-es suit your interests, our 12 new Triathlon training plans are sure to offer a proper & effective fit for your triathlon season.
Share this Post
Interesting. Looks like alot less length on the long rides for the IM High Volume Plan than I’m used to seeing from others. Has anyone used this plan with success? Kinda think this a good plan for those with a big multi-year or multi-Ironman experience.
Michael, these are entirely new plans and therefore not yet tested by our subscribers but everything is based on what’s worked for us in the past as well as a fair amount of input from the most successful multisport coaches who take time to write books and cultivate blogs. 😉
The duration on those long rides is certainly up to each athlete based on his/her anticipated bike split, but with indoor-to-outdoor carryover is often so high that a 5-hour ride inside can equate to a 6 or 7-hour ride outdoors, even on a reasonably flat race course. But there’s nothing keeping you from tacking on extra time in the saddle if you know you’re likely to be on the bike in excess of 5 hours.
And the Full Distance plans are, in fact, aimed at the more experienced endurance athletes. They can be used for a single-peak season and even a multi-peak one assuming the athlete has a deep understanding of how much stress multiple long-course tri’s can inflict on even the best athletes.
