Zwift Alpe du Zwift and Epic KOM GPX files?
Does Zwift generate GPX files? I’m looking to build a TrainerRoad workout around these two climbs - are these files available from someone so I can feed them into workout creator after doing some data mashing? I believe this would be downloadable from Strava?
You should be able to grab the files from these links:
Thanks much for the edit and the assist here, Mcneese. Can I share the workouts created from this?
Yes, you can share, but you need to use the Team function and the workouts within that feature:
