Unsupported Dumb Trainer to Smart Trainer - Ramp Test
I am currently on a dumb, unsupported trainer and I’m about to make the switch to a smart trainer. Using my current setup, my FTP is set at 99. I’m not sure how accurate this is as I am on an unsupported trainer after all. I think it is a low estimate.
I’m going to do an FTP test when I get my new smart trainer set up. Do I need to adjust my FTP before I take the ramp test?
Hi. Shouldn’t make great deal of difference as will just mean test goes on longer/ is shorter if current ftp is off.
Might be worth having a bit of an estimate though - are you a man or a woman? How old? How lomg been training? Do you know ftp of any friends and are you similar/bit weaker/bit stronger then them? 99w is quite low but all relative to size/age/gender etc
I’d be tempted to put it at about 180-200w if male and see how you go
For new users, TR sets the default FTP based on 2.0 watts per kilogram.
So, take your weight in kilograms and multiply by 2.0 and use that for your FTP
  • Ex: 2.0 w/kg X 68 kg = 136 watts
You can do this and adjust the 2.0 w/kg if you think you are higher or lower than that.
In general, setting a lower FTP is probably preferred and will just make the test a bit longer.
I’m a 28 year old male. I’ve been riding for 6 years and training for about 2 now. I’m about 73 kg, so I might set my FTP to 146 as Chad suggests.
2 w per kg is good start point, however 28yr old male, riding 6 yrs, training for 2 - likely to be underestimate…However as Chad says above - better estimate bit low and just make test last bit longer. I’d imagine ftp will be over 200 though given history and age
TR set my FTP @142 for my first ramp test.
45 minutes later…
Outliers… they exist.
Use VAM from outdoor rides to estimate your power for a given time period. That will allow you to get a pretty decent ball park for your FTP. Eg if you have power from VAM for an 8 minute hill climb, take that power number and multiply by 0.9 to estimate FTP.
https://www.cyclingpowerlab.com/VAM.aspx
I just wanted to follow up with what I did:
I manually set my FTP to 150 and did a ramp test that lasted 36 minutes and resulted in an FTP of 227.
