Two Complaints from a New Rider
I signed up for the 7 day trial as a RankNoob™ in the hope I could use the expertise of TrainerRoad (TR) experts to get a good quality training program.
Essentially, I want a bunch of experts to tell me what to do.
My plan is to take on faith that if I do what I’m told by TR experts I can get fitter and faster. If that trust is somehow broken, well… I’ll move on.
Not wanting to sink too much into this effort (financially) for now, I decided to get a speed sensor to use with my basic trainer since the main website excitedly informs me that “Your Trainer is Supported!” when I selected CycleOps and Mag or Mag+.
Complaint No. 1
I assumed, as a RankNoob, that the experts had calculated something called a “power curve” for my CycleOps Mag trainer and telling them I had that trainer was all that was necessary.
But no.
Only after I had triggered the 7 day trial was I presented with the following choices:
[Recommended] Mag 3 (Medium)
[Recommended] Mag 4
[Recommended] Mag 5 (Hardest)
[Powertap] Mag 1 (Easiest)
[Powertap] Mag 2
[Powertap] Mag 3
[Powertap] Mag 4
[Powertap] Mag 5 (Hardest)
What? There are 3 recommended setting! Which one do I choose? What is Powertap?
This is not helpful.
I selected the first one. Why? Because it was listed first, and didn’t say Powertap.
I neither know if I selected the right one, nor know if it matters. The experts didn’t tell me.
For the record, when the trainer wheel touches my back wheel I give it 2.5 more turns.
Complaint No. 2
Before starting the Ramp Test I had two key questions.
What gears should I start out in?
When using a traditional trainer do I shift gears, speed up, both or neither? (ok maybe not the last one)
So I watched the How to Test with the Ramp Test video, read the How to Test with the Ramp Test and read the FAQ page for this information.
Neither question is answered.
The sum total of information about using a traditional trainer is as follows: “For traditional trainers, it’s very important to focus on following the target profile to the best of your ability.”
That’s it.
I even did a web search, watched one TR podcast and a TR youtube video and annoyingly couldn’t even get that basic info.
So without that information from the experts, I was left with trying to figure this out mid-test.
I started in middle front gear with a middle gear in the back. My Cannondale has a triple in the front and 9 in the back. One the first ramp I just sped up, but that caused me to overshoot a lot. Somewhere on ramp 3 or 4 I figured that keeping a consistent cadence and just shifting the gears seemed to work the best. I eventually ran out of rear gears and so went to the big front gear, and dropped the a middle rear gear. I then went up one rear gear per ramp, until I ran out of them, then just went faster until I gave up.
I scored a blazing… ummm… 135(!) FTP…. heh… well… at least I have plenty of room for improvement… right?
It would have been nice to have a more complete instruction on how to do the ramp test with a traditional trainer. I have no idea if or how any of my problems during the test affected the result. I will obviously follow the schedule I was given and am very curious as to what the next three workouts I have scheduled for this week will feel like.
End of complaints.
Well, this will teach the TR folks to give away something for free. Lesson learned🤘
what an awful day to be literate
I want to be constructive, I really do!
It‘s just I can‘t :cry: …
I was a newbie last year and signed up for TR because, while I don’t have competitive aspirations, I live in the mountains, improving cycling fitness was important to me. I did find it to not be very beginner friendly and have mostly just been flailing around. Although I have found that support is VERY responsive so you might have better luck asking your questions there.
The above article should help explain things a little better.
Stuffed if I know what the Powertap setting is. A Powertap to the best of my knowledge is a type of hub based power meter.
Best to shoot support an email if you want further clarification.
Strange…It works for my penny farthing.
I have no idea if this is helpful or not. I first started out with a Kurt Kinetic dumb trainer and did the 8 min FTP test. One year later I upgraded to a smart trainer and did another 8 min test and was within 5 watts of the Kurt Kinetic. I may be way off here, but I think you would be better served to do the 8 min or 20 FTP test as these are just all out efforts and will not require you to gauge your effort every minute.
Thank you for providing this feedback. It helps us as a team better identify how to help onboard new athletes more effectively and we appreciate it!
This might not be worth much, but I’m not sure any of this matters. Ideally 135 would mean 135 watts, but the reality is all trainers are calibrated differently and slightly inaccurate. 135 is the score for you with that trainer with that setting. As long as you continue to use that trainer and that setting, it should be good for you to set workout power targets. That doesn’t mean your FTP is actually 135, but for anyone using a dumb trainer, I’m not sure how much accuracy you can really expect and it doesn’t really matter. FTP doesn’t mean anything other than as a means to set workout power.
Honestly OP, TR is a power based training program. Obv the company doesn’t want to lose a segment of potential customers who have no power meter at all so they (and Zwift and others) have power estimator algorithms, but you really should at minimum have a power meter and preferably a smart trainer with power meter.
You can buy a non drive side pm for like $200-350 if you have a shimano drivetrain. You might want to consider that if you want to use a program like TR.
is this satire?
When used properly and consistently, a standard (dumb trainer) and TR’s Virtual Power can work extremely well. I am all for power devices (meters & trainers, and use them often now), but they are not what I consider “minimum requirements” in any way.
Bottom line, the simple & low cost option can get people to great results.
Actually us old timers will remember that TR started out as the king (inventor??) of virtual power back in the day when power meters cost several thousand dollars and were still rare. TR put a lot of effort into mapping power curves for lots of trainers. Virtual power is not a not some afterthought but for a long time was central to TR and there was a time when a huge percentage of TR users were on virtual power.
Sure a power meter is better and now you can buy one without taking out a mortgage but TR is really really good at virtual power and if that’s all you have, TR will work for you just fine.
Yeah, but unfortunately my 2015 self didn’t actually average 323w for 20mins during an ftp test lol
I have a FSA Vero drivetrain. I investigated the Stages power meter but when I asked them if they had a compatible power meter they said no. The power meters that seems to me to be the best option for me are the pedal based ones. Something like the Assioma UNO, but that’s $428, and the Garmin is $1000. But since I don’t know what I don’t know, I figured spending $20 on a speed meter would be a good test to see if this thing works for me. Also TR seemed like the best option to try as Zwift is too gamified and unstructured.
Per a comment above I’ll just take my initial FTP as a standard to improve from, regardless as to whether it is actually accurate or not. I’ll just keep the setup as consistent as possible. The multiple variable “recommended” settings for the CycleOps trainer confused the hell out of me.
Thanks for all that offered advice.
The settings likely relate to the level of resistance you have your trainer set to. The power reading will follow the correct curve for the trainer, but may be high or low if you have the resistance unit set to a different level than the Virtual Power setting.
Just remember, Virtual Power is fantastic for consistent training, but the number is not of use to compare against others.
You might want to do another ramp test with a higher resistance setting first. Running out of gears before the end of the test doesn’t really work.
Read the article I linked above.
Working out which resistance to use with virtual power on a dumb wheel-on trainer takes a bit of trial and error. TBH I wouldn’t do a Ramp Test to find out! You need to choose a setting where you can spin steadily (70-80rpm) in a low gear for the rest intervals and also achieve the high power values when in the higher gears. One of the short VO2max workouts would be good for this as it will have the required range of target power, but you might not want to do the entire workout :wink:
After that, if you haven’t used a trainer much before it’s hard to know what to expect as it isn’t just “riding a bike indoors”. Make sure you have some good fans to cool you down otherwise it will be really hard work. After a while you get to know what particular levels should feel like. Read the workout text to give you an idea of what any particular workout is about.
On my first time with TR I only had virtual power and a dumb trainer, I’ve still got the same trainer but have a power meter now. Virtual Power is fine so long as you are consistent in your setup: same tyre pressure; same resistance setting on the trainer; etc. The values might not be accurate but that doesn’t really matter unless you are trying to compare yourself to others which really doesn’t work since everyone’s different weight, setup, etc.
As noted by others, when TR started, dumb trainers were the norm but over time more and more people have invested in smart trainers such that it’s almost assumed by TR that anyone starting now will have one.
I’m not really sure why people are making so many derogatory comments about using virtual power. It’s a perfectly valid way to train, just so long as you recognize the limitations (the power numbers are not really comparable with power meter numbers).
Personally, I wouldn’t do a ramp test to start your training with TrainerRoad and virtual power. @IvyAudrain I would highly recommend changing this recommendation to the 8-min test, because if someone is totally new to structured training and doesn’t have erg mode, then the ramp test is really, REALLY hard to do. Pacing for a 20-min test is also super hard. The 8-min test is ideal for this situation. Learning how to follow a TrainerRoad workout NOT in erg mode is something that takes time. It’s a lot to try to figure out for your first or second workout ever, especially if you’re just trying to test out TrainerRoad and see if you want to subscribe.
@xfumbler, I think you’ve already received good feedback that the initial FTP is just a number to start with. The main key with virtual power is to just keep your setup consistent, as you noted. Generally the people on this forum offer useful advice; I’m sorry that there were so many useless suggestions. You have the tools you need to get started, and you’ll definitely get plenty out of the program. I hope that the rest of your trial goes more smoothly!
