I know. I’ve done it a few weeks later after this problem started. It was never fixed and I thought it was my core with problems but with all this guys having the same issues and also since late last year it’s a different ball game. I’ll report it again for sure maybe tomorrow if I’ve got the time.
Yes, please do quote my post. My trainer is brand new, I have a fan dedicated to it just to be sure it isn’t over heating, etc. I have the perfect setup and had never had this problem until November. I thought maybe it was signal interference in my condo, but after trying my phone, tablet, PC and both connection protocols (Bluetooth & ant+), I feel confident my setup isn’t the issue.
This 100% is my experience
Agree… Really doubt is the trainer. I think it has to do with PowerMatch. Last year I was using PowerMatch and had the issue until I quit using it. Used only the Trainer with its crappy built-in Power Meter. Resistance felt a bit odd but never had this problem again in 6 days a week for 5 months. Then went back to using PowerMatch after reading another forum post that highly recommended using it and the very first day I went back to it, I had the issue. And then on the next day… Then I tried ALL of the recommended actions mentioned above and it’s been 3 days without this issue… Could it be that’s finally gone? I really hope so…
Yes, closer is not necessarily better. Even with wireless routers, the most optimal range is a few feet out, not inches from it.
FWIW, I’ve had this same problem. I’ve done most of the fixes that tech support recommended and still had occasional power freezes.
My solution? I run TR off my smartphone with the wireless turned off, running off my cell data feed. So far, so good.
Me too, on last Ramp Test, on minute 17 or 18. Arrgh. Did submit a support ticket, and they did attribute it to multiple intermittent dropouts, which I wasn’t aware of until trainer wouldn’t step up. Got the usual suggestions, look for interference, etc. Since then trainer has dropped out a couple more times, but not at such a bad place – this time indicated in device panel. Had to restart trainer. I’ve blamed Direto, but maybe it’s not the only problem. As others have noted, this behavior seems recent, and it seems to be not only Direto.
Coming up on another Ramp Test in a week, and inclined to just shift through it in Resistance Mode like the old days. Anybody else do this?
Support really has to take this on their priorities. I’ll pick my previous report and make a reference to this topic today if I can. Hope it’s really a bugg that came with some update made late last year.
Just another bug example. With Netflix it happened for some months. Really bad image and constant freezing. Netflix declined responsability blaming my internet provider. Internet provider said all was okay. Done all the setup configurations both suggested. All the same. Then finnaly it just stopped happening. They both declined responsability but one of them for sure must have done something so this got finnaly solved.
Had this yesterday, and the last time I used a turbo. I normally do workouts on the rollers so wouldn’t notice, but both times I’ve used a turbo recently it’s stuck on the ‘high’ power at the end of the last interval, so not ideal! No changes with hardware so I’d agree it’s likely in the latest update.
I’m on Android but have the option to use the PC version, are people having problems on that too?
I’m using a pc with with windows 10. Had tryed once my cell phone with android but it happened anyway.
Drastic measures!
That’s the main note. Nothing has changed except some updates on TR.
Your neighbour and everyone else’s on this thread, sounds unlikely!
I have experienced exact same behavior, Kickr (2016), assioma duo, ANT+ and using powermatch, running MacOS version
Sometimes it only last few minutes, so if power is not too high I can sustain waiting, sometimes it’s too high and legs are on fire so I stop, tried to disconnect and/or restart
Last time this happened (yesterday !) I have disabled powermatch and all was good, tried to enable it back and got same issue again
I have noticed this happened during my low cadence (55) interval, and I have noticed after powermatch being disabled assioma reports higher Wattage on high cadence but lower Wattage on low cadence than my Kickr ![]()
See, that’s the weird thing with mine. It’s always 10 seconds. And, it doesn’t happen every time, but just occasionally. Yet and still, when it does happen, it’s always 10 seconds. So, that seems to me to imply some particular, repeatable problem is occurring.
This is exactly what powermatch is for, to compensate the mismatch between power meter and trainer, especially because it isn’t linear.
Me too, (although not on Neo) I thought it was the CABLE update but looks like a TR issue…
Lets hope its solved for you but I´ve had complete workouts of over 1h without no problems but then the next day some problem’s and from time to time more than a dozen power freezes.
I’ve reported this and sent the link for this topic. TR support is on this specific problem of power getting stucked. It’s not the usual power drops that automaticaclly get recconected after a few seconds.
Had another one yesterday, changed PM battery before (new, branded battery), calibrated, and all was well. Than about 25min in, all three devices dropped out at once (PM and HR on ant+, trainer on bluetooth). They all reconnected, but when the work interval started, no resistance change happened… Dis- and reconnected PM, no change… disconnected trainer and switched from bluetooth to ant+, and PM again - that fixed it until the end of that session. Still frustrating, and now I don’t think the PM battery was at fault anymore. With both an+ and bluetooth dropping out at the same time, I doubt it’s an issue with the ant or bt driver? Though usually when I get this problem, I don’t actually see that anything disconnected, though if it reconnects quickly, I might not notice.
