Tacx Flux S - what gear should I be in?
Hi All, I’ve had a tacx flux s for 2 years and starting to notice that some rides my power will flucuate or be very spiky and not at smooth at holding the power as it use to be. I did a ramp test the other day and towards the end the power was all over the place.
I feel like this is hindering my ramp test and not giving me a accurate FTP result.
I’m wondering if I’m in to big of gear and what gear other people that use a tacx flux s are using.
I have the Tacx Flux as well. I believe TR’s documentation states that you should be in the small ring in front and in a middle gear on your cassette.
Tacx Flux S - Gearing / accuracy - Equipment - TrainerRoad
It is best to use a lower flywheel speed. This will give you a more accurate power number.
Thanks, I’ll start using the small chain ring from now.
