Tacx Flux S - Gearing / accuracy
Good evening,
First of all, my native language isn’t English. So if i made a typo or grammar error, please excuse me.
Once every while I check my data between my Tacx Flux S and my Precision 4iiii left power meter. Just to see if everything is on par.
In the latest workout I noticed a large difference between the data when shifting gears.
After I saw this, I recorded a workout with both the 4iiii and the Flux and tested if the power difference is there across all gears. This isn’t the case. There are just a few gears where the wattage (ERG mode) is close enough.
I’ve tested with the workout Carillon +1. After the warmup I’ve calibrated both devices, and begin testing. I’ve started with the 34 in front and the 22 in the back.
Every next step (every 2 min’s), I’ve shifted one gear. In the first interval, 34/25 the tacx couldn’t deliver the power so I’ve ran the 22 for the first 4 minutes.
"Interval 1: ERG
34/
22
22
20
18
Interval 2: ERG
34/
16
14
13
12
Interval 3: ERG
50/
25
22
20
18
Interval 4: ERG
50/
16
14
13
12"
34 - Low cassette
In case you want to run the data in DCR Analyzer:
https://drive.google.com/drive/folders/1HDiulje_NgevDhsICLoJT6ImLyx2nONw?usp=sharing
Only the 34/16 en de 50 / 16 provide the same power numbers.
Is this just a flawed Tacx Flux S? Or is there something else I’m missing.
The power accuracy of many trainers vary with spindle speed (the equivalent of the wheel speed). So the same power at a different gearing will result in a different accuracy. In general, the faster the spindle is turning (i.e. the longer or “harder” gear you’re using at a given cadence), the more error there will be.
As this is becoming more widely shown, I wonder if trainer makers can review the issue and maybe work to dial in that variation at higher speeds? I don’t know if it comes down to them establishing power data at fixed wheel speeds outside of what we see in these examples or another reason.
But it sure seems like there is a potential for these variations to be closed to some degree and make them more accurate across the speed range.
I know Elite has sent users custom firmware mods to bring the two lines closer; that’s quite a lot of fiddling honestly (the concept of sending data points to someone in Italy who modifies a firmware load and sends it back is such a low-tech/high-tech combo, all that’s missing is using a fax in the process). An “Advanced” calibration mode that would allow a power meter user to enter a few set points and set a calibration curve would do miracles. It’s not rocket science.
Can this be a difference of like 40 watt ?
34/22 -|Avg Power| Tacx 248.44 w| 4iiii 238.49 w|
50/12 - |Avg Power| Tacx 254.84 w| 4iiii 280.99 w|
If so, does every trainer has this issue?
Not “every”, but certainly many.
One of the reasons why it’s generally recommended to do your ramp test and your main intervals in a similar gear selection. That eliminates the variation - you set your training level and measure your workouts in the same “precision” range.
I can’t recall, but @gpl & @dcrainmaker , do you guys ever take this into account when reviewing a trainer unit ?
I check for it, but I haven’t seen anything like you’re showing in a long while. That’s odd. Usually the issue I see with ERG mode and using the big ring is set-point accuracy responsiveness (how long it takes to stabilize), not power accuracy per se.
In your case, having a left-sided only unit makes it tricky to know for certain.
Note that while some trainers do still struggle with high flywheel accuracy issues, but for the most part I see that more in SIM mode than ERG mode. Most of my ERG-related high flywheel issues are around set point responsiveness/accuracy.
I thought of a L/R imbalance, but my RPE and HR went way up during the 50 - 12 and 13 sets. So yes, its tricky to know for certain, but i’m pretty sure it’s an accuracy “issue”.
Although i’m a bit bummed by this, I will make sure for future workouts that i’m in exactly the same gear. So that my training and testing is identical measured every time. 34/16 in my case.
Thank you all!! Very helpful to understand the problem.
I’m just glad it’s not only me! I’ve got the Flux S and the power readings are next to useless. I certainly cannot be bothered to test a whole bunch of gear combinations in erg mode to work out which is most accurate. Well done to you for doing it, but we shouldn’t have to.
It’s slightly depressing that in 2020, so many years after power meters came to the market, and a fair number of years after smart trainers came to the market, it seems that we’re still in a position where, a lot of the time, data produced by smart trainers is unreliable if not downright useless.
I run a left-only power meter (I couldn’t afford a dual power meter at the time) and regularly wonder just how far off my readings are. :pensive: I know that’s just the nature of left-only power meters, and prices have come down a lot recently, but smart trainers do seem to be variations on rubbish for power reporting.
This is your problem. You have two sources of power. If you had just one source of power, then it would always be right :rofl::rofl:
On a serious note, I think tracking down the answer to your issue will be a frustrating effort. There’s a lot of potential variables at play. Here’s an example of one - does your power source use average or instantaneous angular velocity in calculating power.
This is why people generally recommend to use a preferred source of power, and stick to that.
Separate note: this issue is another reason why no one should take Zwift racing results too seriously!
Agree. I was highlighting that issue as an example of one of a number (many?) things that makes it challenging to accurately diagnose what’s going.
