Another review on Reddit complaining about the Wi-Fi issues I’ve read about several places. Seems the core cooling functionality is great, but other issues with things that are necessary to use like Wi-Fi are really hurting the user experience. Also sounds like customer support isn’t helpful either. I’m still on the fence with this one…
Whatever they used for their WiFi antenna sucks. I have an access point on my back porch and the bedroom is just above that. Finally tried opening the back door and the bedroom window and was able to connect. Guess I’m going to have to add an access point near the bedroom.
from the front. not sure if it’s from the reservoir area or not. a quick chat with support and they’re sending a replacement. thankfully the ooler units work with the new mattress pad, so we have a backup while we wait.
I just ordered a sleep 8 pad. Will review after some experience. I’m coming back from a long break off the bike and some minor illness. My legs go full Chernobyl when I train regularly so I’m looking forward to testing this bad boy out.
Just ordered the Dock Pro. While I wouldn’t consider myself a hot sleeper, I do tend to wake up a couple hours before I’d like to get up and not be able to fall back asleep. Hoping this helps, and if it doesn’t the 30 day trial makes it a risk free experiment.
that happens to me too. you could try setting a schedule and use the warm awake (or whatever it’s called). it turns the temp to high 20-30 min before your set wake time. if i wake up and the bed isn’t toasty, i immediately know it’s not near time to get up. i feel like that helps me get back to sleep. in podcast terms, reduced cognitive load?
Anyone without AC using one of these successfully in the summer? I don’t have AC, and New England summers have become a lot more like Florida summers in the last few years. I have a window AC unit in the bedroom, but it’s loud and obnoxious, and it’s always a pain to install/uninstall every year. And my wife and I have different ideas of what a good temp is.
FYI - I purchased one of these access points and installed in the bedroom. Luckily I already had a hardwired network jack in the bedroom which made the install even easier. No more connection issues to WiFi. Kind of sucks that I had to do that considering no other device in my house has trouble connecting but is what it is. These TP-Link units are pretty easy to set up.
Also curious to hear what your experience is with needing to fill the reservoir? It’s basically running dry every 1.5-2 weeks which is way faster than the ooler. My assumption is that since the reservoir lid isn’t sealed that we lose a lot to evaporation? I have looked for any leaks and all is dry.
mine needs water about the same. it’s nice that the app now indicates whether the water is low, but it’d be even better if it’d send an alert. at least i don’t see a way to turn on low water alerts.
I would think evaporation would not be ideal. my assumption would be a full system would be able to cool much more efficiently than a partially full one. My ooler is sealed. I dont see noticeable water loss month to month.
This one works a bit different than the ooler in that the water doesn’t flow through the external reservoir. Best I can tell it feeds and keeps an internal and reservoir topped off.
7 nights down on the Eight Sleep and I’m an absolute convert. The ‘mesh’ network of channels disappears when you lay down on it. You can feel it with your fingers but not really when laying down. The unit itself is surprisingly quiet.
Its pretty great having a single unit being able to manage both sides of the bed. for a test I did a late evening 3 hour ride in relatively high heat…and since I haven’t been training until recently 3 hours at high end of z2 in heat was a great test. My legs were on fire like I had just done a crit or something. Typically this is a recipe for sleep disaster. Not anymore. Got in bed to a cool mattress, fell asleep immediately and stayed asleep almost all night (not normal for me). 8 hours later (also not normal for me) I woke up and my HRV was bounced back up into the fully recovered zone.
The additive affect of having great sleep night after night is going to be fantastic. I really can’t believe I didn’t consider this type of sleep system before. Thanks to @Nate_Pearson for initially planting this seed and the threads here for keeping it top of mind.
Now if I could only figure out how to make a travel version of this!
