Moved the interval summary to the bottom of the workout graph, increased the text size, and added scaling based on window width.
Minimal mode interval summary text size has also been increased.
Fixed an issue where elevation data was displaying incorrectly for outside rides with no power data.
Calendar days should now retain their expected size even if workout images havenāt loaded yet - this should prevent some ājumpinessā on initial load and when scrolling.
Figured Iād add a +1 to having this issue when I did my Ramp Test tonight. Workout was visible online right after the workout, but FTP didnāt update in the app or online until I quit and reopened the app. Also, Iām guessing this is related to the issue, but the workout also didnāt associate with the scheduled Ramp Test workout until after everything updated. This is on the Mac Beta version 2019.25.1.41 for reference.
I gave the Mac desktop beta a try tonight and it looks nice! Really liking the keyboard shortcuts in particular. Ended up running into trouble with erg mode & PowerMatch, though.
A few intervals in to Spencer +2 I had to cut my effort short and take a breather, so I switched from erg to standard mode (~32:20) to ride out the rest of the interval at a lower resistance. Then, after the recovery valley started a few minutes later, I turned erg back on (~35:00). The target power was a constant 127W at that point. The trainer brought up the resistance until I was at about 250W, though, and stayed high. After a couple of minutes it was still way off. I ended up going back to standard for most of the remaining time in the workout.
The first time erg cranked the resistance too high is shown here at ~35:00:
Initially I thought the wonky resistance might have been from Zwift, which was also running. Iāve accidentally paired it with my trainer before and had something like this happen. Zwift gives conflicting instructions to the trainer and the resistance is wrong until I tell it to unpair the trainer. I checked, though, and it wasnāt paired with the trainer this time. I closed Zwift just to make sure that wasnāt the issue. Then I gave erg mode a couple more tries around 41:40 and 46:50 just to see if it would do the same thing again, and it did ā the resistance went way too high & stayed there.
Out of curiosity, I also tried turning off PowerMatch for one interval. That worked fine. The resistance tracked the target power pretty well. Itās only when PowerMatch was on that the resistance spiked.
Feel free to check out my ride data ā itās the one on Tuesday, Jun 18, 2019 at 7:15 PM.
I reported a similar experience some 6 days ago (scroll up!), after switching from ERG to Resistance I couldnāt then get the trainer back into a stable ERG mode. I also suspected Zwift grabbing the trainer, but also this wasnāt the case. Note that I also have power match on and didnāt try turning that off.
Havenāt tried it since, looks like this is an issue. Iāve heard nothing back from my report other than they were going to look at the workout file. Maybe itāll be bumped up now in has had āmultipleā reports and more data and experimentation done by you to go on!!
I think youāre probably right. It might just be taking a while to upload. Do you both know your Internet speeds? I donāt think you need anything blazing fast, but Iām just wondering and trying to gather some information.
Iāll issue this up with your reports. Thanks! (And good job on the Ramp Tests, by the way).
From the behavior that youāre describing, it does sound like thereās something going on with PowerMatch when swapping between Erg to Resistance/Standard and back.
At this stage I canāt say what exactly is occurring, but Iāve made a formal issue and an engineer will have a look at some point in the near future.
If we determine that there is an identifiable problem, Iāll be sure to let you know. Thanks for your patience until then.
+1 here with the Mac sleep causing the TR beta desktop app to crash problem. Itās a nuisance when trying to do the oft-suggested thing of getting your trainer and workout all set up the night before to be ready to go first thing in the morning. I always took that all the way to loading my workout and entertainment and then just closing the MacBook Pro clamshell for the night.
Sorry I donāt know about the internet speeds but all the other rides are syncing pretty instantaneously; Iāll get off the bike and strava will be telling me the ride is uploaded.
@ming Iām in the same boat. Not sure about internet speeds, but other rides all sync right away suggesting it should be fast enough. I can do a speed check when I get home though.
@Scheherazade@kelseyh If all your other rides other than the Ramp Test are syncing to Strava before you even get off the bike, itās probably not a speed issue. Itās more likely a Ramp Test-specific bug.
This is issued up and Iām gonna try more test scenarios to reproduce it.
Really like the look of the new version of the app, and Iām looking forward to getting the grid version of the calendar. It works well too, but I have found something that may be a bug.
When scrubbing across the workout to redo a section (or presumably move forward, āthough I havenāt tried that) the confirm and cancel buttons donāt work as expected. It takes a long time to acknowledge that either has been pressed. Each time Iāve tried to use this feature I have actually pressed the button 2-3 times as nothing seems to happen for, perhaps, 20 seconds (I havenāt timed it). I donāt know whether this is anything to do with my ageing computer but it doesnāt have issues with any other aspect of TR or other apps that I use regularly.
Also, as others have mentioned, Iāve also noticed that the app will crash if left open for extended periods ā itās quite obvious as the fans on the computer are audible. I tended to leave the current production version open the vast majority of the time but canāt with the beta.
Final things to mention relate to the interval summary text. When in full-screen mode, Chadās workout text and the interval summary text seem very close (overlapping?) each other at times. When in minimal view Iād prefer it if the interval summary still flashed up in the main part of the screen. I have my computer about 1.5-2m in front of the bike. Often the TR screen is in the minimal mode so that I can watch Eurosport. I donāt have a hope of reading the interval info overlay on the left part of the screen and Iām happy for it to obscure the view of the video for a couple of seconds. However, I understand that the majority of people might like its new place.
ok has been working well for me until this week, but nothing major
the workouts are fine, dropouts appearto have stopped, but this week immediately after a workout I had a white screen. Couldnt do anything but shut it down.
And nothing major but my last three rides havent pushed through to Garmin or My fitness pal - do I need to reset these up and if so where is this now??
Windows latest version (updated this morning - twice!)
Agree. Iād like to be able to choose in the app to pair by ANT+ only. i think users now are using multiple connections, zwift, Garmin, TR etc. There is possibly some interference between the different connections. When i switch of BT on my laptop and connect ANT+ I donāt have any issues. Not that i have frequent issues as i donāt. But I like to connect TR by ANT+ on laptop and other items by BT. However, training at 5am in the morning I need my Bluetooth headphones to connect to my laptop for music, Netflix etc so being able to disable Bluetooth in the app would be super useful.
However, feedback on the app is really positive. looks great, works great, can now actually run TR and Netflix at the same time on my old PC. The app is a massive step forward. thank you so much for all your work on this.
Platform: Windows 10
Version: 2019.25.2.45_Beta
Devices: Kickr Snap/Assioma Uno
Connection:ANT+
Mode: ERG/Resistance - Power Match enabled
Wanted to provide further data regarding the issue previously noted where switching from ERG to resistance mode creates instability in power and making this feature unusable. Please note I donāt have any issues switching between ERG and Resistance modes when using the āstable releaseā version
I was cheering too early. The above helps just once. When I quit and start the program again all my workouts in the calendar are gone again all dates show āno planned workouts or racesā .
