Zwift Integration on TV and Tablet?
In other words, if I am using the Zwift/TR integration on Apple TV can I run the TR app on my ipad simultaneously?
The purpose is just to be able to see the TR graph in old school mode.
Thanks!
Why don’t you just use the app to run your workout?
You can then connect to zwift as power source only - you don’t need to use the integration.
If you literally just want to see the blue bars then use the mobile app instead - it looks identical and won’t try to control your trainer.
Thanks for the feedback!
I never thought of this. I’ll check that out. In the end I’ll probably just use the integrated option but was just curious.
Prior to the integration I just ran workout on my ipad in TR and just connected trainer to Zwift for power. Make sure the trainer is not connected under “resistance” in Zwift. Worked great for me in the past. Truth be told I think TR does a better job of holding to the power targets than Zwift, particularly with intervals that slope up or down. But Sometimes I just like the simplicity of doing it all in Zwift.
