Workouts feel too easy
I’m looking for guidance on whether I should adjust volume or intensity in my current plan.
I’m on a 4-day-per-week plan (2 hard rides, 2 easy rides), which was the recommended structure. I’m three weeks in. The two hard workouts feel appropriate and productive, and I’m confident they’ll get even better over time.
The issue is the two easy rides. They feel extremely easy, borderline unengaging, and honestly like a poor use of time. I’ve listened to all the TrainerRoad podcasts so I fully understand the purpose and value of low-intensity and recovery work, so this isn’t about dismissing endurance rides. I just want to be sure I’m not undertraining.
I’m considering increasing workload to hopefully drive faster FTP gains, but I want to do it correctly and avoid overtraining. I’m curious how others handle this situation when the easy rides feel waaayy too easy:
  • Do you leave them as prescribed?
  • Replace one easy ride with something more substantial?
  • Adjust plan volume instead?
Looking for best-practice guidance rather than guessing.
Can you give us details of your easy rides, please? Either a screenshot of your calendar or a description of duration/IF/TSS.
I’d rate them as easy and let AI do the thinking it’ll learn and up the intensity and if you still feel you need more volume use the check volume feature down the line.
How to Change your Training Plan Volume – TrainerRoad
I would go in and change the Endurance slider to encourage the AI to be more aggressive.
Go to your calendar. Click the training approach named at the top of the page (Balanced, Aggressive, Custom, etc). Click edit. Click “Customize by zone”.
Thanks for the quick responses and the helpful suggestions, everyone. @Helvellyn Here’s a screenshot from today’s ride as an example. The workout is 3×10-minute intervals at 140 W and 2×10-minute intervals at 107 W. I also had a similar 45-minute workout on Monday, which felt like almost no effort.
Yesterday’s ride was a 1-hour sweet spot workout, which I rated as moderate, and today I feel fully capable of doing more. Craving something like a longer tempo ride, for example.
Very interesting, thanks for the tip. I wasn’t aware I could customize by zones. This may be what’s needed, since the hard rides feel productive while the easy rides feel excessive in how easy they are. Thanks again.
I love me a 0.65 IF Endurance Ride. Almost as much as I love a 0.60 one.
That being said, I do them in the context of them being at least 2 hours at that intensity, and with 2 (occasionally 3) hard hard days per week on the other days.
This may be your issue, based on your general description I would likely be rating these easy. What is the AI expecting them to be? If it’s expecting them to be easy and you’re rating them moderate it’s unlikely to increase the intensity
@pirnie Yep, I’m definitely rating the endurance rides as easy, and the AI is also predicting them to be easy. The ride I rated as moderate was a sweet spot workout, which the AI predicted to be hard, but I was feeling particularly strong yesterday.
  1. You could switch to 3 hard, 1 easy and see how that goes for you
  2. Generally, I wouldn’t recommend increasing the intensity of endurance rides.
  3. Do you have the time for more volume? If you do, I would recommend more time at that 60-70% area. More volume is almost always better IMO as long as it is at the appropriate intensity and doesn’t negatively impact your “hard” days. With more volume you can also increase time in zone on your hard days. So instead of 4 x 8 you now have time for TR to give you 4 x 10.
  4. If you’re answering the post workout survey honestly it’ll adjust. It sounds like you’re answering them honestly from your example.
Apologies, saw the screenshot and didn’t fully read the text I quoted - ignore me :person_facepalming: - not enough coffee
That is supposed to be an easy (or very easy) workout. My plan is on a series of them at the moment as its a recovery week; last week was much harder Anaerobic and VO2max workouts and next week its back to hard SS and Over/ Under Threshold workouts.
Great suggestions. I definitely have time for more volume. What I’m starting to understand is that increasing the endurance ride volume ( say from 45/90 minutes to 90/120 minutes) keeps the risk of overdoing it relatively low, as long as the intensity stays in the prescribed endurance range and it doesn’t negatively affect my hard days. If this is correct, I’ll likely start there and see how the AI responds. These longer low intensity rides will definitely require queuing up some good podcasts!
That is correct. The only caveat I’d add (and this may just be my personal training philosphy) is that there is no reason to be pushing that edge .75 IF or 75% ftp. As Helvellyn said “I love me a 0.65 IF Endurance Ride. Almost as much as I love a 0.60 one.” Queu up some good stuff and enjoy.
Thanks for all the great suggestions, everyone!
I think there are some good suggestions in here, but going to add a couple more.
You could adjust one or both your endurance days to dynamic endurance which would increase your time on the endurance rides. Assuming you have time in your schedule for it. This builds up and won’t instantly put you at a 4 hour ride this week.
You could run volume check on your plan and see if there are additional days/extended time you could ride.
As mentioned previously stop the masters plan and go to 3 intensity/1 endurance. Don’t know your age so not sure if this is appropriate or not.
Answer your RPE surveys and wait for the AI to dial up the intensity and wattages. If you are just starting it’s not a bad idea to leave some room for growth. You’ll get to the end of your plan and be missing the easier days/rides if you scale up too quickly.
Also could you post your training calendar or training days? This may help us see what’s going on. Schedule would be very different with 4 days slammed together, evenly spread out or like a 3 and 1 scenario.
If you are only riding 4 days, you recover on the days you are not riding. I don’t really see the need for additional recovery rides. Personally I would use the two “endurance” days to ride outside if you don’t want additional intensity.
If you can’t ride outside I would change one of the rides to something more stimulating… a “C-workout” of sorts. Something that is very doable but also engaging enough to keep you interested. The fourth ride would be long endurance if you can handle being on a trainer for longer periods. I struggle over 90 min so use rides like “Bays” (has a few accelerations) or tempo intervals as those can help with the monotony. If the added stimulus starts to add too much fatigue dial it back.
Best of luck to you!
Jumping back in to respond to the recent comments. Thanks for your comments, everyone. Your feedback prompted me to dig deeper into my training plan settings. I initially went with TrainerRoad’s recommended setup, which put me on a Balanced training approach. As I mentioned earlier, that ended up feeling too easy given that I’m looking to put more into my training.
@Elgro I’m 50 years old. I’ve been a mountain biker for years but am relatively new to endurance cycling (gravel), with a couple of gravel races coming up in August. I kept the plan on Masters for now, but yesterday I switched to a Demanding training approach and set the endurance rides to Dynamic. My upcoming calendar now looks more productive, with five rides per week and longer endurance sessions. Especially given that I’m in Vermont, where temperatures have been consistently in the single digits and far too cold to do much else outside.
Two screenshots for context:
  1. The first ~2.5 weeks on the Balanced plan
  2. The upcoming weeks on the Demanding plan
I think you have a few options here.
You could change your general training approach to something higher, which will change how we look at all your workouts. You now have the option to adjust your training approach for each zone independently, so you could turn up endurance exclusively to see if that helps.
You could use Workout Alternates to find harder versions of the endurance workouts we’re scheduling.
Since Endurance workouts are capped at 75% of FTP, once you get to a specific workout level, you need to increase duration to get more stimulus. Long rides can be fatiguing, even at 75% of FTP or lower, so I’d make adjustments slowly.
Finally, switching to three hard workouts a week might actually be the most productive first step in terms of getting more quality work in each week. I usually recommend athletes start with three hard workouts each week first, then start to build out one long ride a week, and add a fifth ride after that if it works out. :+1:
