My workout are not loading in Zwift. I tried to replaced and also tried a different workout and it is not syncing. Not sure if it’s a zwift issue or not. Suggestion? is there a way to manually sync?
Thanks,
Patrick
Thanks,
Patrick
Doesn’t help you but I’ve had a similar issue with workouts not syncing to Garmin. Or the steps don’t sync so a workout file with the correct name gets sent but there isn’t an actual workout.
Same here
Had a similar issue twice last week. Found a tip that worked. Close Zwift. Go into TR app and drag workout to a different day, then drag it back. Open Zwift. Worked a treat
Mine synced this morning.
Turns out that TR have only started to sync the day of the workout instead of 3 days as in the past. According to support. Thanks everyone. You will only see them day of going forward.
Patrick
I had this yesterday. I logged out of zwift, switched off the TR/zwift link, reactivated the link, logged in to zwift.
Hey all, we did indeed have some issues syncing certain activites with Zwift over the weekend/ yesterday. We understand the cause, fixed it, and are working on a permanent fix to prevent this specific issue from happening again.
This bug could theoretically have also caused some issues with Garmin syncing. @LookingProGoingSlow can you DM me your username so I can investigate? I don’t see an active TR account associated with your forum login email address.
I had the same issue. Reactivating my Zwift account and syncing it fixed the problem once. The problem isn´t fixed.
Did you have this problem today?
Yes.
OK, I’ve forwarded your account to our engineers.
same for me
@Olly did you have a TrainerRoad workout today (3/31) that failed to sync over to Zwift? We see your activity from yesterday (Monadnock -1) was indeed affected by the bug, but I’m not immediately seeing any scheduled workouts that should have synced over today.
We looked into this—this was indeed the bug we’ve since fixed. Your timezone is several hours ahead of us so your workout was impacted by the bug before we implemented the fix. You shouldn’t see this happen again, but let us know if you do.
Thanks must of been the bug from Monday it was showing today.
Not wanting to start a new thread. I have not had an issue until today .
Question: If today’s workout happens to be on a Red Day, will TR not push it to Zwift? It did not show up on Zwift. I added it again to my calendar and it still was not pushed to Zwift.
Thanks
Whatever you have on your calendar for the day should push over. If it’s a red day and the rest day replaces your workout, we won’t send anything. But if you swap it back to the workout/ add a workout on that day, it should send over.
When you look at your calendar, do you see the actual workouts? Or are you seeing “Rest day” replacements? If you’re seeing Rest Day, you’d need to click the little tab above it showing your original workout type and then toggle that back to be your planned workout for the day.
