Apologies if this has been discussed but no luck with search button.
The workouts I do on Zwift are not matching to the TR workout on the calendar. Probably because I do extra warmup and cooldown on zwift.
I remember we used to be able to match workouts to scheduled ones on the calendar and I can’t seem to find it. Has this feature been removed or moved or am I just missing it???
I will have the team take a look at why these workouts aren’t associating automatically, but you can accomplish it from the calendar on web by right-clicking the ride. You can also do it from the apps by clicking on the completed ride, scrolling to the “Associated With” section at the bottom of the screen, and then clicking in there to select the planned workout with which you wish to match.
In your example there, the Tallac -1 Zwift activity actually is matched with its corresponding TrainerRoad workout (as evidenced by the TR icon on the workout map and the Workout Level appearing under the title), it just didn’t remove the planned Tallac -1 workout from your calendar. That’s certainly not intended. We’ll take a look to see what’s going on.
The other issue was that I had Tallac-1 on calendar today. I moved tomorrows workout Manly to today since I felt good and did that 1st. After that, Tallac-1 disappeared and I had to manually add it back on the calendar. Not sure if that’s working as intended or if it’s a bug.
On the plus side, the moment I added it back to calendar, it was instantly there in zwift. Well done on that solid integration.
That also sounds like a bug and may be related to the lingering planned Tallac -1 activity stuck on your calendar. Thank you for the additional context. That will help us find the underlying issue.
