Workout name, graph, and details on calendar do not match
This has happened to me a couple of times now since the new AI model released. The workout details that is on my calendar for the day does not all line up. The name of the workout shown is incorrect and for a different workout than the graph shows.
Example:
Calendar Name - McKinley
Calendar Graph - Is for the workout White +6
Calendar TSS - Is for the workout Mckinley
When I click on the workout. I get all the White +6 info and can execute White +6 workout.
Where this gets problematic is that I use Zwift integration and Zwift is getting McKinley sync’d as my workout for the day. If I wasn’t paying attention I would have done McKinley which is a very different workout. And lastly it was difficult to find a workout around to get Zwift to load the correct workout.
I tried resyncing, restarting TR and Zwift, using TR and Zwift on multiple OS, moving the workout to a different day and back. None of these had any meaningful impact.
I had this issue today. Calendar showed Isaak Walton -1, but the workout I actually got was Brush. These are similar workouts of the same length, but different ALs (2.5 for IW and 3.9 for Brush). Also interesting: while my calendar showed the Izaak Walton -1 workout name, it showed the Brush AL. And at the start of my workout (done in Zwift), the on-screen text said “Welcome to Izaak Walton -1”, even though the on-screen workout title was showing Brush.
It seems that there might be some wires crossed somewhere.
Hey @JRitchey :slight_smile:
This looks like a bug, so let me look into it!
Can you also post a picture of what you are seeing on Zwift if this happens again? This helps us see whats happening live on all things you’re describing.
@Caro.Gomez-Villafane If it happens again I will take additional screenshots but I don’t currently have an example. This has happened twice, on different days. So, it may happen again but I currently don’t have a screenshot. Just the description that the incorrect workout, McKinley, was being synced when White +6 was the intended workout.
@caro.gomez-villafane Here is a new example. With a slight twist. Correct workout this time is Carter but info from McKinley is loading again. The name on TR is still not aligning with the stats and graph but this time when I click on it I get the wrong workout loaded, McKinley. This time while the wrong workout is loading on TR the correct one is loading on Zwift, Carter. This is inverse the behavior that happened last time.
Let me bring this to the devs and get back to you!
