Hi everyone I have been researching the best smart scales lately because I want to track my health and fitness progress more accurately. I’m looking for a scale that can measure more than just weight—things like body fat, BMI, muscle mass, and other body metrics that help me betterunderstand my overall health.I’ve checked reviews from trusted sources and also looked through verified customer feedback.After comparing several options, these three stood out as strong choices:
GE Smart Scale
However, I’m having trouble deciding which one would be the better option, and I’d really
appreciate some advice from people who have used either of these scales.For context, I want something that is accurate, easy to use, and connects smoothly with a smart phone app so I can track my progress over time. Features like multiple body metrics,
reliable Bluetooth syncing, and support for apps like Apple Health or Google Fit are big plusesWhich one would you recommend? Any pros, cons, or real-world experiences would be really helpful. Thanks in advance
Are you wanting accurate weight measurements or accurate body composition?
Any decent scale does fine weight wise, I have a garmin one that uploads the metrics to intervals and trainingpeaks.
for body composition I am unaware of any home scale that is accurate. I think they work well enough* for trends but you should probably do a dexa scan periodically if you want to accurately track body composition.
I’m assuming that you want a scale that measures body composition and connects to a smartphone. Otherwise any cheap digital or analog scale will do.
Three good choices are Whithings’ line-up of scales, Garmin’s scale and Tanita’s range of smart scales. You can see Tanita scales in e. g. gyms and such. We have a Whithings scale at home, and it works well. We bought it in Japan so for some weird reason it only measures ± 200 g even though everywhere else it offers ±100 g.
I always liked the old-fashioned double beam balance like docs used to have. That’s what I had and used for many years. IMO, more reliable than the spring type mechanical and who knows what’s going on inside the digital ones. You’re on your own in getting the data into your apps. Health o Meter 402KL Physician Beam Scale | Vitality Medical
the only reason to buy a garmin scale is if you are invested in the garmin training ecosystem with their watches and bike computers - the index scale is the only straightforward way to get weigh-ins into garmin connect.
otherwise, they are rubbish scales. the body composition seems to be based on BMI mapped to population averages. you can set a known body fat % for it to base off but even then, as far as i can tell it only adjusts based on weight changes, there is no significant ability to differentiate between fat, muscle and water. they also adjust for age which clearly has no direct relationship to body composition - they just guess that if you’re older then you’re probably higher fat, lower muscle.
the wifi uploads are mostly reliable but not great which is actually pretty bad for this day and age.
i had an old fitbit scale that seemed to be better for both body composition and upload reliability.
withings seem to be regarded as the best all round if you are platform agnostic
I am definitely all in on the Garmin ecosystem, watch, scale, BPM, HRM, head unit, varia lights, etc. So take this with all that bias built in, but if you really care about the accuracy of the data beyond weight the Garmin S2 after calibrating with Dexafit data has been super accurate for me. It’s not dead on with my Dexafit every time but stays very close for Body Fat % and Skeletal Muscle Mass as long as you follow the same protocol for when you use it consistently which are the two things I really care about tracking. I think results vary for people based on if you set your activity class correctly and set your body composition correctly using Dexafit data and I have read that your age may impact data in some way? But for me it has been great after not really loving the S1 scale that I never felt was very accurate on the BF% but that one didn’t allow you to calibrate with body composition data.
While the Garmin smart scale might not be completely accurate, it is precisely consistent. That is, the measurements are consistent across time so it accurately tracks changes to the measurements it takes.
