TR can't connect more than 2 devices over bluetooth
I’m using TrainerRoad with Wahoo Lickr 2018. Also, I have Wahoo cadence sensor and HR monitor. Besides of Wahoo Kickr, TR can connect only to one of remaining devices. So, I can’t use all of them simultaneously. Kickr calculates some estimated cadence but sometimes it is incorrect (usually when “real” cadence - estimated by me - reaches ~ 120 RPM). In that case it may show 150 RPM that I believe it is not possible for me (at least yet).
I use TR on smartphone with Android 9.
Can this issue be resolved somehow?
Can you connect to any of them via ANT+ ?
You may have better luck contacting support@trainerroad.com for this.
It may be more of an issue with your Android device, because I am not aware of a device number limit in the TR app itself.
Phones and Tablets only support Bluetooth
ANT+ is a protocol used mostly for Fitness Related Devices
As @mcneese.chad stated, contact support@traineroad.com for help with this issue.
FWIW, I can connect my STAC Halcyon, Generic S/C, and HRM all via BT to my Galaxy Tab A simultaneously. The only issue I have is that I have to turn off BT on my phone or the S/C won’t connect to the Tab, it sees it as a device but won’t transmit data.
@rockrabbit - my Galaxy Tab A supports ANT+
Samsung Galaxy S phones support ANT+
Seems odd. To my knowledge, both Android devices and the TR app can support many more than 2 BLuetooth connections.
Maybe you are connecting the Kickr as a cadence sensor (I believe the Kickr also transmits as a cadence sensor) hence the TR app won’t see your Wahoo cadence sensor?
What android phone do you have?
I routinely connect 3 bluetooth devices on my pixel 3
smart trainer + power meter + heart rate monitor
I can connect 3 BT devices as well. Using the Wahoo Tickr, Wahoo speed sensor and Stages left crank power meter on an LG Stylo 4 phone.
Is this an andriod update or TR andriod app update? I always could connect all my devices until last night, then I could only connect my PM and HR or HR and Trainer to my Pixel.
All 3 played nicely with my Fire tablet that isn’t set to auto update everything.
2 existing discussions that may be related?
Thanks guys.
I think I found the reason. However, let me first answer your questions:
I don’t have any ANT+ adapter yet. And my mobile devices don’t support ANT+.
I think, I’m not. Smartphone displays Kickr itself, cadence sensor and HR monitor. It just don’t want to connect to all of them.
Huawei Honor 10.
It was from very beginning (actually from time I bought HR monitor).
And here is the reason: Honor Band 3 on my hand permanently connected to my smartphone. Before now I tried to disconnect it but probably it connected again in seconds. This time I decided to not give band any chance to reconnect and I put it into microwave oven to be 100% sure. And smartphone finally connected to all 3 devices. Now I’m thinking about pressing start button on MW oven because it was very annoying :slight_smile:
