I have a plan based on a 240 mile event with a lot of climbing. I’ve been following the plan and it’s worked well thus far. But for some reason on race week Tuesday (race is on Saturday) it’s suggesting I do Stromboli -1 which is 45 minutes total but has 3*8 minutes at suprathreshold. Am I missing something or does this seem like way too much effort that close to a long race. I’ve loved the plans with the new AI but I feel like both recovery and taper weeks have been way off and adding way too much fatigue
Let me know what you’ve experienced and if I’m off in my assessment
I for one, know my body and do my own taper before an event. If you think it’s too much then do what works for you. ![]()
Fair. But I also pay for this to build me a program and I’m trying to understand why the program feels spot on until taper week and then it makes no sense to me
The same taper may not work for everyone. I also felt mine was way too high and changed to a proven one that I know worked for a prior race.
But then why have a plan? I’m just trying to figure out what’s happening. The taper didn’t use to be this brutal. I’m trying to figure out if there’s a logic to it or not.
I like to go into a race with a little fatigue so I don’t feel flat. Works for me.
I agree with that and I like intensity over a short workout on race week but the long suprathreshold seems like a lot more than usual to me.
Tough one. I never did anything intense in the week before, including not even liking a day before “opener”. I’ve since tried more intensity, including openers, and I can’t say it’s a massive difference. My point is that I doubt that intensity in the taper week would hinder you and it doesn’t seem outrageous to have it recommended.
When is the race? Have you marked it as A race or B, C race?
Race is on the Saturday and the suprathreshold workout is on the Tuesday. It’s marked as an A race and the plan is built around that event. Just trying to see if it makes sense to do that much intensity that close to a long event.
@jrfmricher TR has a history of screwing up the taper week in plans…probably that issue is long since resolved but that experience has always left me gun shy when it comes to plan taper weeks. So that’s one thing.
Another thing…sure, taper weeks are a thing based on physiology but, just as important, tapers are a mental thing. Taper weeks should leave an athlete well recovered but also confident. Because of that the best approach can vary widely depending on the athlete. Don’t cram an athlete through what science says is the best taper protocol if it leaves that athlete so anxious that it’s a distraction.
My advice is don’t do the workout if you’re going to lose sleep over it. Maintain workout frequency, do a little threshold intensity…just enough to keep blood volume up. Sleep lots. Eat correctly. Visualize success. Smile a lot. THIS IS GOING TO BE THE FUN PART. The hay is in the barn. Whether you do 3x8 min threshold Tuesday or 3x2 min threshold or whatever, it’s not going to make much difference come Saturday.
I’m with you, last season I did a taper and it left me feeling tired for my A race then about four weeks after I had my best performance of the season in the race that was two after the A race.
I never understood the whole taper concept and only tried it with the TR plan.
Looking at what’s on the calendar this year, I think it’s setting me up for a repeat of last season.
I have enjoyed keeping some intensity and reducing volume on race week. I just feel like they’re pushing me into too much fatigue territory this time especially with such a long event planned. I’ll likely change it but I’m trying to understand the logic of it all.
I definitley don’t think that 3x8 at 102% is too intense for a taper week.
It’s not an easy workout, but it’s not that long or all that hard. The goal is to keep sharpness whithout bringing fatigue, which this workout would achive, especially with your race four days later.
Some people expect taper weeks to be easy, but they aren’t always. You’ve got to find a way to keep your fitness from falling while you try to recover at the same time and these shorter, harder workouts are designed to do just that.
Did you have any other hard workouts scheduled between Tuesday and race day?
Ok sounds good. I’ll try it out and see how it goes. No other hard workout in between
Everyone is different and tapers are personal. I know some who like a full day off before an event. I know others that taper hard the week before then get back on the gas the week of as too much easy makes them feel flat.
But as mentioned 3 x 8 min at threshold (or slightly above) shouldn’t be over fatiguing. I mean I have my own taper the week of the event but also don’t follow a plan to fidelity. But if you are one who does, you should do it and give it a try. If it doesn’t work make some adjustments for next time.
This is the way. Those hard workouts the week of should be a reduction in total work compared to a loading week. With almost a week until the event i would prefer about 75% of the work, then do a second a few days later around 50%. So if one was at the level of doing 4x8 at 102% that prescribed workout is spot on.
I posted my typical taper week in this thread: TR not tapering much before Leadville - #7 by ingluis29
I don’t know if it’s the most optimal but works for me.
i like that setup and that usually works for me. i think it’s the longer suprathreshold that surprised me. in part it might also be because i’ve raced a lot this year (for me) and the fatigue has been piling up. I think i’ll probably swap it for a slightly easier workout depending on how i feel after this weekend. The taper did start this week and I am starting to feel a bit more fresh which is a good sign
