Taper week workouts make no sense to me
@jrfmricher how it went?
Race is next Saturday. I still think I’ll go a bit easier on Tuesday but the taper is starting to make me feel fresher.
Keep in mind that taper workouts can be intense, but they should be based on the work you have already done. If you were doing 4x11-13’ at 100-105% in the last couple weeks… doing 3x8’ 102% is not so hard. Or if you have been doing 3x 15x 30/30s… doing 3x 7x might be pretty easy as well.
But yes, in taper for many — shedding fatigue and getting there fresh is smart!! But depends on the type of race, duration, etc!
Wouldnt fancy 24mins of suprathreshold the day before the race, but 4 days out ?, for me id be OK recovering in time for that.
But everyone has their own tapers and you know yourself better than anyone how you would react to the workout.
e.g. I find I run better if I do a sprint interval session on the bike the night before the run :man_shrugging:, it shouldnt work but it does
It is called a pre race primer meant to activate the fast twitch muscles without generating too much fatigue. A 240 mile hilly event will still recruit fast twitch muscles on some of those ascents. Plus 4 days before is plenty.
yeah i definitely want some intensity. this is very different than what my plan had been doing although i guess a lot of the over unders were similar. I settled on a slighly shorter version of 4 x 5 suprathreshold which i think will help activate while leaving me fresh for the big ride
100% this, context is everything!
I feel like taper weeks are individual but I find my lead up best if I do a threshold or harder effort workout 4-5 days out, a few light endurance rides, then two days of openers at around 30mins each with some real all out efforts in each.
I tried a two week taper before a fondo with no efforts the day before and I showed up really flat the day of the event.
I just did a 70.3 following a TR plan and my initial reaction to taper week was similar. The plan had long suprathreshold intervals on Tuesday and longish sweet spot intervals on Thursday. The race was on a Sunday. It seemed too close to race day to go hard, and I was worried when I could feel the Tuesday workout in my legs swimming and running the next day. But it worked out great— I was itching to go by Saturday and crushed it on race day.
I’ve had similar confusing workouts given for a taper week. 2 days of 4x20mins at FTP. I did contact support and said there’s no way I’m doing those workouts that were WL 9.xx and they agreed that I should follow my thoughts but it could be whether it’s an A or B event on your calendar.
I ended up doing an easier version of the workout because I felt i was carrying fatigue from a warmup B race the weekend before and it was hard but didn’t really dig as much of a hole as I though. Went to a 5 x 4 minutes suprathreshold instead of 3 x 8. Did some openers on the Friday and felt great saturday. Long day on the bike with 240 miles and 18K ft of climbing but we got it done in just over 20h with stop and honestly I still felt strong at the end which i thought was a good sign about how well the plan worked overall
I agree that the taper week for larger events like the one you’re describing is often not great. I used TR to assist with building out my training for Lotoja this year and was very underwhelmed with the taper and ended up adjusting it heavily to better match the preparation needed.
Agree JMGant - seems to me as the duration increases (Or if user’s w/kg is lower for a fairly long event.. (not hyper competitive)) then it is much more important to shed as much fatigue as possible, be as fresh as possible… at the expense of maybe being flat a bit.
For a long Fondo/Gravel/Leadville type effort where it just becomes a battle of attrition, attacks/covering/bridging are not a thing for 99% of riders.
yeah for most of my races so far it made a lot of sense but for this one I erred on the side of caution because I had never done anything this long before and I think i made the right call. I really had to approach it much easier at the start in order to still have matches at the end. It mostly worked since I still had legs left for most parts except for the super steep parts.
Am I reading this right, your event it 240 MILES? 3x8 above threshold should be nothing but an early primer for you. With 3 days after to rest and rejuvenate you should be totally fine.
For future reference, you should take notes on how you feel the following days and see if this taper works for you.
My taper week is coming up and it looks like this: My typical training week is about 10 hours so these short, intense sessions are perfect to keep the intensity up while not racking up a lot of time on the bike.
Good luck on your event!
yeah it was 240 miles with about 19K of climbing. I did a B race the week before so i was a bit tired which is why the intensity worried me. I turned it down a bit 4 x 5 instead because I had never done anything as long and demanding before and wanted to be fresh. It all worked out great and I got it done. Brutal day but the fitness and freshness were there
Not exceptionally hilly (unless concentrated into a small portion) for the distance. The B event a week before is the mistake you made. Really should not be that close to an A event, unless it is after.
Well, done, onwards and upwards
