Replacing a TR session with a zwift race
I’ve recently got into Zwift races (having just done workouts and freerides for years). If I’m due to do a hard TR session, and I do a Zwift race instead … do i just go into the calendar afterwards and delete the planned session? Anything else I need to know/do? Thanks.
You shouldn’t even have to do that….
However, there have been a few reports of Zwift rides being erroneously linked to the planned workouts. So TR ends up thinking you have done the workout but you haven’t.
So it would be a good idea to check that hasn’t happened - or you can delete the workout before you go on Zwift to ensure it doesn’t happen in the first place.
If you right click on the planned TR Session before you do it, you can then select “Replace with Zwift Race” and TR then does the switch in your calendar.
This is the way :backhand_index_pointing_up:
Thanks @Norry1!
