Hi, I had to restart Zwift in the middle of a planned TR/Zwift workout. On restart, the TR workout has gone, I can’t find anywhere in the Zwift interface, just the next planned one in a couple of days.
I assume this is because the TR/Zwift integration thinks I’ve completed it, even though I haven’t.
What’s the easiest way to get to do that planned workout again in Zwift?
Add anopther instance opf the workoiut to your trainer road calender ?
What’s showing up in the TR calendar? Is the incomplete workout there? If so, is it associated with the original TR workout? If that’s the case, I’d unmatch it from the workout and see if that gets the original workout to re-sync to Zwift.
I suppose you could also put another copy of the same workout in the calendar.
I can’t find the original planned TR workout in either the TR calendar or Zwift feed, so not sure what exactly the ride I need to search for.
I added a test workout into my TR calendar for today, and it did show up in Zwift, after restarting Zwift. Is there a re-sync option in either app to avoid having to restart the whole app?
Hey @Gwydion
To answer your question, the easiest way to get it to show on Zwift again is by re-adding it to your Calendar on TR. You shouldn’t need to restart the app to see the new TR Workout on Zwift as it syncs automatically.
Sounds like maybe there was something going on with Zwift. What prompted you to restart it?
Also, I don’t see it on your Calendar, but when you went to TR, did you see the ride file of the uncompleted TR Workout?
If so, then it makes sense you had to re-add the workout as the original was already “completed” with the Zwift ride data.
