Is there a way to drop in the tri swim and run plans into sweet spot base?
Thanks in advance
Thanks in advance
Sadly, no.
The easiest way I can think is the following:
Apply your desired Tri plan to the desired date.
After applying the plan to the calendar, deleted the unwanted workouts from the calendar.
Apply your Sweet Spot plan, presumably at the same start date as the Tri plan. Set the rides to the desired days.
This will effectively βstackβ the workouts from the plans onto your calendar.
thanks
