Does Plan Builder default to ramping PLs and TSS, as opposed to, or in addition to, hours? For me, it seems to have gone right to my max hours in base 1.
Same.
As someone who liked the Easy button approach before, I’ve found this transition to be somewhat frustrating.
Thanks for the heads-up! We’re looking into this now. ![]()
For the time being, I’d recommend using Workout Alternates to replace any workout that’s not the duration you’re looking for.
I’ll let you know when I have something more to share.
Thanks!
Sounds good. To be clear, I don’t have a problem with the “ramp” in the blocks being a ramp in TSS and PLs, but it was more to understand if that was intended behavior for the app. I guess my expectation would that TR would have a target high for volume (in hours) and build toward that through the plan.
@Yep @jmkizer, how are your plans looking now? It seems like this problem may have resolved itself… ![]()
Let me know either way!
Thanks again!
@eddie just wanted to also point out that once you have a plan on your calendar and you click on a block to change the custom workout durations you are limited to a max of 2 hours.
Hey Eddie, yeah, in my base (HV) for example, it went right to 10:15 hours for each of the 3 weeks, and it doesn’t ramp up from there. It also started at basically the max hours for each day, right from the start. The rest of my phases, looking ahead, do the same. The ramp is in TSS and PLs, so there is progression, just not in hours.
@msegues Not all workout types can be over two hours long. It looks like here you’ve selected “Hard Intervals,” which max out at 2 hours. ![]()
“Easy Rides” and “Endurance” max out at 5 hours.
thanks @msegues! I’ll have the team take a look at this… ![]()
It looks like something funky is going on here…
It sounds like this has been addressed by the engineering team and should be fixed in one of the next updates.
Thanks again for the heads-up!
