One HR signal, TR and Z seperate
Quick question. Now that TR and Z integrate together I get that one HR signal can be used by both platforms.
If I use TR on an iPad and Z with ATV (old hack) and I only have 1 BT signal, which program should be linked to my strap. I care most that TR has HR data for accurate analysis but wonder if there is a way that both are served.
I can upgrade to a multi BT strap but still curious about a 1 channel solution.
thx
I use a Garmin monitor that send Ant+ and Bluetooth.
I have it so Zwift uses Ant+ and TR on Bluetooth.
The monitor also has dual Bluetooth
Hey @Dale1328
Bluetooth is a 1-to-1 connection, so if you pair your HR to TR, then it won’t be visible to Zwift and vice versa.
If you care most to have your HR data on TR, then pairing it to TR is the way to go, unless you broadcast ANT+ and BLE like @Kendogz161.
You could also just complete your TR Workouts on Zwift (with all the data there) and let them sync over: How to Complete TrainerRoad Workouts in Zwift
Hi and thx for the response and all resolved. Be great!
