Need Support or Nate to clear this up. AI. FTP isn't working out for me
Hi all, I’m the same theboycooper who posted on r/trainerroad about the recent AI FTP changes, and I wanted to share my full experience here so TR staff can see it in one place.
Context:
I’m in a key training block with important rides in April, May and June, so I can’t really afford to waste 3–4 weeks or even longer as it learns on under‑powered workouts while a new model “learns” me. Recently:
  • My last Zwift ramp test (the day after the new TR update) gave me an FTP 249 (243 W at the time I posted on reddit).
  • Intervals.icu had my eFTP 238 W.
  • Old TR detection was 235 W.
  • The new AI FTP detection suddenly dropped me to 212 W.
So all of my external and historical data pointed to me being 240watts ish, and yet the new AI put me at 212 W and then built all my workouts around that.
The Core Problem I Ran Into
The issue isn’t just a “my FTP is wrong by X watts” complaint, i’m 42 and past bragging about such things, it’s how that wrong number propagates through the whole platform and how hard it is to correct without turning off the very AI features i’m paying for.
At 212 W, my workout levels were coming in around 3,4,5, when I know I should be around level 7–8 or even 9 for the 212 metric.
When I override FTP manually to something sensible, AI‑driven features (AI FTP detection and adaptive workout selection) effectively stop working or are degraded.
I did a proper FTP test on Zwift the day after the update and got 249 W, but the TR AI did not react or adjust based on that effort.
Even when I completed harder workouts, the system did not immediately “snap” to a more realistic FTP, instead it appears locked into a 28‑day AI detection cycle and sub par difficulty suggested workouts
Practically, that means, accept an obviously wrong FTP and spend weeks on too‑easy workouts, or fix FTP manually and lose most of the AI value TR is now built around.
I’m having to Hack this.
I’ve found a hacky workaround that at least stops me wasting a month, but it really shouldn’t be necessary.
What I’m doing now:
I accepted the low AI FTP so the system would “believe” its own number and keep the AI features active.
For each scheduled workout, I manually bump it to around level 7.x and will be higher over the next 2 weeks in the appropriate zone.
I then complete those sessions and mark them as “easy” or “moderate/comfortable,” which they genuinely are for me at my real fitness level.
Over days, the system has started very slowly nudging future workouts upwards, but nowhere near fast enough to reflect a 30 W difficulty discrepancy.
This at least lets me avoid weeks of sub‑par training, but it turns me into the tuning mechanism for the ML model rather than the model working for me.
How This Feels As a Paying User
From my side, a few things are frustrating:
  • The new model seems to have pulled many of us towards the middle of a bell curve and then expects us to climb back out via a sequence of artificially easy workouts, making it look like we’re progressing because the system is slowly increasing difficulty.
  • When AI FTP is plainly wrong, the tools to correct it (tests, hard workouts, external data) either aren’t recognised or are heavily throttled by the 28‑day detection window.
  • If you do the “sensible” thing and put in a manual FTP you actually believe to adjust workout value, you lose the main AI features you’re subscribing for.
  • It feels like we’re alpha‑testing the new machine‑learning model on our limited training time, without clear documentation on how to work around obvious mis‑estimations.
I’m not anti‑TR or anti‑AI far from it. I want this to work, and I’ve stayed on the platform because the structure and library are valuable. But this update doesn’t feel baked from a user experience standpoint, especially for people in an important training window.
What I’d Love From TR
I’d really appreciate if TR could:
  • Provide clearer documentation on how AI FTP detection interacts with:
    • manual FTP changes
    • non‑TR tests (ramp/20‑min efforts on Zwift, etc.)
    • completion of very high‑level (9.x) workouts in different zones.
  • Offer a supported, explicit “my AI FTP is clearly wrong” recovery path that:
    • allows a one‑off re‑calculation sooner than 28 days, or
    • allows a manual override without turning off AI adaptation entirely.
  • Communicate more openly that the model may significantly under‑ or over‑estimate some profiles at launch, and what those athletes should do right now.
In the meantime, I’ll keep using the level 7.x workaround so I don’t waste the next month of training, but I’d prefer to rely on the system as designed rather than hand‑tuning every workout.
Keen to hear if others have found better solutions or if TR staff can clarify the intended behaviour and best practices for cases like this.
If you’ve not already tried this, is it worth temporarily setting Training Approach to Aggressive to help ramp things faster towards your true ability?
I did the ramp test
I did level 7 and higher workouts to completion and marked them easy
It’s not made any difference and still thinks I should have level 4 workouts
Maybe support can help and just turn the daily up so they are relevant as right now as a user. This new platform doesn’t work.
Have you opened a ticket? If so, what did they say?
The TR one or a zwift one?
Pretty sure the recovery path is schedule a TR ramp test? :thinking:
Also, @BCoopers , post your Calendar if possible.
I am surprised the TR ramp test didn’t set your FTP higher
You can see what i have done this week.
Next week is a 5.2 and i changed to a SS 7.9
then the rest is all crap
posted
opened but only today so maybe reply next week, never used support before
Better than screenshots would be to post a link to your Calendar & having made it public (temporarily!), if that’s possible? It’s much easier for people to follow things when viewed in situ….
They’re usually pretty quick and helpful, although maybe they will be busy right now due to the new system - if you are really finding level 7.x workouts easy (straight after a new FTP) then there would seem to be some issue.
I think most other people are having the opposite problem! The workouts at my new TR FTP look very optimistic… although I did get a nice one today that actually worked out pretty well.
I think support will suggest a TrainerRoad ramp test.
But your calender doesn’t look too bad - is that a predicted FTP of 235w in a couple of weeks?
Looks as though the system is already compensated for your low FTP by prescribing higher levels workouts - level 7.9 sweetspot next week for instance - then after that future FTP of 235w you are back to level 4 like you should be
I’m curious on this whether higher level workouts is better, or increasing the intensity of the AI-selected workouts. Hopefully something TR can weigh in on as well (aside from how best to override FTP).
To clarify: my first thought in this situation would have been to complete the workouts at say 110% intensity, rather than choosing higher level workouts at what you think is a too-low intensity. If it’s true that the system only cares about what watts you do in the workouts, this would seem a good way to kick start it. But not sure…
Do you realise that the workouts in your calender following that 235w prediction will use that 235w FTP value? Maybe that isn’t clear?
What does week commencing 9th Feb look like?
You have clearly hit a bug where your FTP has been set too low - the system has corrected itself looking at your calender - but it must have been really frustrating regardless.
If you want to fix the situation now then put in a manual FTP of 235w. You will loose the predicted FTP but on for a couple of weeks until you next detection date.
Good catch, that could explain the discrepancy.
Everything after the prediction uses the new ftp of 235 watts, so workout levels will be lowered.
I don’t see any threshold rides in the screenshot before the prediction, but it looks like there’s a sweet spot 7.9.
@BCoopers Are the levels before the ftp prediction also too easy? And are the rides after the ftp prediction reasonably appropriate wattage wise?
There seems to a bug for me where the post prediction rides show the correct watts, but still the pre prediction ftp. That’s probably a huge source of confusion.
What did your training calendar look like for the 8-12 weeks before now?
hit am miss, with lots of TTT zwift races and outdoor sunday rides, with ome workouts in there. 90% indoor but the AI i thought would be better.
So it’s getting better but this should have happened day 1 and having to manually make the workouts useful.
It’s almost like a game getting the FTP detection to the right level VS trustinig it.
