First am jealous because the Accutrend system is really nice and you can measure other stuff with it just by getting different strips… That said, it’s not really meant for sweaty athletes as a DIY device.
The blood gets pulled onto the strip “pad” by capillary action. Have you tried getting a good bubble and bringing the strip down to the blood bubble rather than the finger down to the pad? The latter is how most videos show testing. But the videos are for cholesterol, blood glucose, etc. e.g. not sweaty bike riders.
Most test protocols you’ll be sweating from working hard on the trainer. I always try to get my test finger as dry as possible before pricking. I use paper towels then a wipe with alcohol soaked pad (standard stuff). Then obviously wipe off and discard the first bubble and test the second bubble.
Any chance of getting an assistant to help run a test or two to help get good data?
You could do something like a vLaMax test to drive a high value of lactate. That stimulus plus a helper to do the finger stick and sampling would give you confidence that the meter is functioning properly.
The test protocol is a warm up, then an all out 30 second sprint. Full gas. Take a sample asap and then another every 2-3 min until you reach baseline. For purpose here of just getting a decent data set and testing the meter, you could do the 30 seconds, then take a sample every 3 min for 9-12 min. That would give you a curve. Note most vLAmax protocols will test every 60 seconds after the sprint. But you won’t be able to test that quickly to start so make it easy and do the sprint then test every 2-3 min. We’re not after a perfect curve at this time, we want you to get some good measurements with your meter.
You could also guess-estimate your 2-3mMol point and do a ride at that pace. Something around 80% FTP ought to do it. Perform a 15-30 min effort and take a sample every 5 min or so. Just to get you in the accurate range of the meter.
All ideas. Perhaps someone else has the Accutrend and can me more specific.
Stick with it and you’ll come up with a routine to obtain good data!!
