This is the second time I’ve seen this. I did a workout in Zwift this morning. I took a ~90 second pause after the warmup for a quick stretch and to calibrate my power meter. When I view the workout, it looks like it imported fine at first glance, but the intervals are all off (I believe because of the early pause). So, when reviewing intervals in the list, all the wattages are wrong (since they overlap with the rest interval). And when I click on an interval, the highlighted section doesn’t match that actual interval for the workout. I saw this once previously with a zwift workout when I had an early pause. I just started doing workouts in Zwift this year, so maybe that’s just the way it works and you can’t stop without screwing up the data?
Everything after the pause is slightly shifted to the right and has the wrong wattage for the interval -
