I’m not in AT, but have been following along the discussion, and I think you’d be best served currently to use the alternate thing and select a workout a bit higher in level.
The recommended levels right now are way too low (I did a 5.1 sweet spot workout with ease), so I can’t wait to be admitted into the AT beta. For now I need adapt it manually. I find the Alternates not as useful as the variants screen that was nixed. I wish I could have both.
So i manually changed my FTP setting, since it was too low for outside riding. Ive been doing the workouts outside - however, i dont get progression levels any longer - eventough I did alot of workouts. Its beta I know - but a bug to mention here
@bnied @Nate_Pearson
Still looking for a good answer on this - If I drag and drop a plan workout onto a different day, does it still disassociate it from the training plan and view it as a skipped workout, or not? @IvyAudrain
If it does then I think it should be added to the list of known issues - I don’t see a reference to it there (and actually it should be added with a resolution even if it doesn’t since I know I am not the only person who would like to know).
I’ve been using the option to change the default workout days to move the workouts around, but this is also imperfect because it also resets the adaptations, which is fine for future workouts in the block as it simply re-adapts them. But if you are pulling a workout onto today it won’t then re-adapt it back to what it was, because AT doesn’t adapt workouts on the same day (plus it’s much more of a faff compared to drag and drop in the calendar).
Dragged/dropped workouts are still dissociated, as of June 14 per support:
We are actually currently working through a bug that causes workouts to dissociate when they are dragged and dropped, so I would avoid dragging and dropping workouts until they are within the current week.
Typically, each week has one workout of each type, which means that their outcomes will not typically affect workouts within that week. More often, they will affect the workouts in the subsequent weeks, so it’s safe to adjust within that week. From what I know at this point, dragging and dropping should dissociate the workout, excluding it from Adaptive Training suggestions.
It’s a Plan Builder bug, not an AT bug, so it’s probably tracked separately. (I agree it should be part of the AT docs/FAQ when they get published.)
Thanks for the heads up. I reorganised this weeks plan this morning using what i thought was the safe method of changing the default days in the block. I just checked and I too have lost my adaptations in the process without any preview to say it was doing so.
I had issues last week with these auto adaptations that i worked through with Support, but never got an answer as to what might be triggering them. Maybe this was it.
I’ll submit another ticket now
Well, I did find that future workouts re-adapted back to what they were almost immediately. The only adaptation I lost was the one for the same day - on Monday, I pulled a workout from the Tuesday to the Monday by adjusting the plan days. The future block workouts all reset to the defaults, then I got an adaptations pending message and they went back to what they were. It was just the one that I had pulled from Tuesday which didn’t adapt, since AT doesn’t adapt same-day workouts (fortunately I had the planned workout open in a browser window, so I just swapped it back using Alternates).
I’m on SSB MV2 and the Recovery & Sunday SS ride stayed as they were (never adapted anyway), but the the other three workouts have all changed automatically. I had taken a screenshot as backup before changing the days, so I’ll go manual if need be tomorrow
Ticket submitted
Plan Builder has been out of beta for a while now and this is still a huge bug. It breaks plan builder, and now AT, when shifting a workout, which is such a basic thing!
Ah, that makes sense, but it has much more impact now AT is tied in with Plan Builder… I never really noticed it before.
I got added 5 days after my Birthday so there’s hope for you yet!
Did FTP test today and all my levels dropped to 1 except 2.1 endurance. Muh gains!
Need to train myself to ignore levels and let RoboChad take the wheel.
Nate also teased an unreleased feature on the podcast last week that will allow you to nudge the level of the workout up or down on the day so you can fine-tune based on how you’re feeling. So it sounds like more options for workout swaps are on their way.
I’m glad it’s going to be easier to make changes to workouts, but I’ve had to update almost every single workout since my last ramp test as AT has wanted to make things way too easy for me.
The alternates tab has been a big help, but its still a little bit annoying to have to change so much of the plan.
I am following a training plan built with plan builder. I had a workout planned for Saturday that I knew I wouldnt have time to do, so on Thursday I dragged and dropped the workout to Sunday and also picked an alternative. I got an increase in PL. So it worked for me.
Correct. Completed workouts will contribute to PL changes, even if they are moved from the default day applied via PB.
The problem is that moving future workouts breaks them out of PB (and therefore AT), so they will not be adapted by AT as a response to PL changes or things like Struggle workouts. If you move a workout that is a few days or weeks out, it will not receive any adaptations from AT, no matter how much your related PL changes.
As such (and until TR fixes the PB bug), I suggest delaying movement of workouts until the last possible moment before you plan to perform them.
Hope some can answer this one for me. I have a lung scare and can’t really perform at the high end. EG last ramp was 289 but happily training at 315 so how and when does the system update my FTP based on work completed? I’ve had a look about and a search but can’t see anything that points this out
Currently, AT only updates your FTP after a test protocol (generally a ramp test) or if you manually change your FTP. So it essentially is no different than it was prior to AT.
FTP prediction is not currently offered by AT, but is being tested internally at TR for the future. There is no clear timeline on when this feature will be pushed out.
I just read my reply from support, and I can add the moving of workouts via the Plan Builder scheduled days managed to disassociated my planned workouts from Plan Builder and subsequently from AT, hence the auto revert to non adapted workouts.
For completeness, one day of the week managed to stay linked and adapted, but the rest reverted.
As @ellotheth said, the initial problem is a Plan Builder one, but given AT’s current dependence on PB, it has been submitted as an AT bug.
In the meantime, once I have got the plan reestablished, I’ll only make changes via the late change as per your post
Does this also apply if you messed up the workout days when setting up PB? I screwed up and placed 3 of my MV workouts on the same day every week. When i realized that I went back into PB (I did not drag and drop within the calander) and moved the workout days to the correct days of the week that I wanted.
