Just signed back up to TR. A bit disappointed that there’s been no changes to pick a plan.
I currently want the best plan to increase my FTP while doing one Zwift race a week.
I’ve been through the UI through build about 5 plans so far with different goals and focuses trying to find the one with the highest FTP prediction. I have to manually try all different loads on each plan as I can train up to 10 hours a week and it only ever defaults to 6:30~ even though increasing it manually then ups the predicted FTP. Seems very janky. Is this the intended workflow?
You would think the increase FTP plans would increase your FTP the most, this isn’t the case
Has anyone got the best plans to try? I’m an anerobic rider so am mainly interested in increasing the power I can do at LT1 to bring up all my zones.
can only hold 270w for an hour AIFTP 293.
Do people still use these or is using adaptive training the better way to go for long term gains? (presume someone has noted down the predicted ftp from a plan then compared what they got through adaptive training in 4 weeks at some point?)
Tbh the prediction focus you have is possibly not the most optimal way to increase FTP. The best plan to increase your FTP is the one you can complete sustainably and consistently. As an Anaerobic rider, even if your FTP doesn’t increase much but your LT1 becomes a higher percentage of your FTP then that represents a win that wouldn’t be meaningfully display in your before and after FTP values.
The workouts and FTP predictions change after every session so looking at it so far out isn’t worth much.
All plans will be a little different depending on the type of racing you are planning on, most of the differences though I think are in the specialty phase. Picking the plan based on the 1st phase of training block’s predicted ftp gain is NOT the way to go about picking a plan.
You’d want to pick the one that at the very least gains the most FTP over the course of the PLAN (months!!!) - the 1st small chunk of base phase is just that …a few weeks. You really would want to pick the one with the LOWEST gain of FTP in my opinion! All the plans are goin to use AI Adaptive Training to adjust your training based on your training that you do. So they will raise/lower workouts as you go depending on success/fails/RPE/skipped workouts, etc. You can set in the plan the length of workout each day and set number of days, set a dynamic long ride on the weekend… etc. The onboarding is fairly conservative at the start to prevent burnout from new riders jumping into HARD structured interval training, so not surprised it started lower. Can adjust as you go very easily, can add rides to your calendar manually - although if it is too much, the AI will downgrade workouts on yellow/red days to prevent failed workouts or piling on fatigue that will cause issues next week or after.
Good luck on your training!
I empathize with your sentiment of spending a bunch of time testing different durations manually and checking predicted FTP given the default timing. Even when using a year long plan and using the check volume feature routinely, when I create the next plan it will reset me to 3 or so hours less than what I was already doing based on their recommendations. The onboarding being conservative only makes sense if it’s not considering current and previous consistent TSS levels which it claims to do. If it analyzes my training history, (which is all TR for the last few years), and then suggests 2-3 hours less then it has to be wrong either on the new plan or the old. This isn’t a false dichotomy, but seemingly a limitation in the current capabilities of the AI they’ve built. I’m sure it will continue to evolve and get better, but for now it still seems to require some user interference.
