Help fix in-ride text typos; post them here 👇
:rotating_light: Extraneous question mark detected :rotating_light:
I did Sill -4 today and the first break after the first warm up SS interval started by saying something like “get both feet back into your pedals” as if the preceding 2 minutes at 95% were ILT. Pretty sure I didn’t see any ILT text.
Just checked The base Sill workout and it does have ILT between the warm up and first over-under intervals.
At 11:37 in Bird is:
“They’ll start out tought but manageable…”
Should be:
“They’ll start out tough but manageable…”
Fixed! Thanks for catching that!
Joe Devel -5. The middle two sets a comment comes up on both that says something about “half way” between the second to last and last interval. Probably a comment from the full Joe Devel.
Not quite a typo but Broken Finger -2 is reporting as a 32 minute outdoor ride when it is pulled by my Bolt. It looks like the 2nd set is missing
Capture
45mins into Mary Austin - everything becomes blurry and illegible.
Is this an in-ride text correction? Or the app/workout itself becomes blurry and illegible?
Err …
I think you’ve been had!
Thanks, we’re fixing that as we speak! In order for you to get the fixed version though, you’ll need to push it to your Wahoo head unit again after we’ve published the edits (any minute now!). :+1:
Antelope about 52:30 or just after - “you abdomen” I believe should be ‘your’
Outdoor Tallac today. Outdoor workout text says - Main Set: - 3x15 minutes between 182-195. Head unit was 178-198. Not far off, but different. I know these are calcs based on FTP, but would assume you would want them to be the same in the text and head unit.
Hey! We tried to recreate this on a head unit to see if we could recreate it: no dice. Do you mind getting in touch with support so we can take a closer look and see what’s amiss?
You can email them at support@trainerroad.com, or submit a request online. Thanks in advance!
striped +1 24:00 references 2 upcoming efforts but there is only one.
edit: also at 46:40. it’s the last interval in each set
Hey! Im showing 2 efforts following this text, so it looks correct. Can you confirm that you didn’t do a +/-variation of Striped?
JK I just noticed this, fixing now! Cheers!
Screenshot_20201022-214048
dade+4, 53:05
screenshot attached.
That next interval cracked me. maybe the cognitive load of contemplating uploading the typo to trainerroad. :wink:
Workout named Junction at about 1:02:57, the word “seconds” is spelled “seconnds.”
