Ah, that makes more sense, cheers!
We should launch our updated AV system today! It has a lot of goodness but also 11 people in a ride and custom workout support.
Everyone will have to be on the latest release for it to work, but it should prompt everyone.
The release Nate mentioned has just been pushed out to everyone! It includes the following updates:
- Increased workout limit to 11 instead of 5.
- Added the ability to do Custom Group Workouts
- Added a more reliable audio/video service.
- Added ability for Host to remove another athlete from a Group Workout.
- Added ability for Host to turn off another athleteās mic or video.
- Added ability to report other athletes.
- Added new keyboard shortcuts in addition to tweaking some existing ones.
- Fixed issue where you would be removed from a Group Ramp Test if you didnāt have power and selected to āend testā.
- Added sound indicator when second athlete joins a Group Workout.
- Fixed issue where live FTP value could still update once test portion of a Ramp Test has completed.
- Added more clear error messaging when you are unable to join a workout.
- Added new settings panel that more clearly breaks up different app settings.
- Fixed issue where Hammer H3 displayed resistance mode instead of Standard mode.
- Disabled workout text sounds for Group Workouts.
- Removed 0,1,i,l,o from new Group Workout codes.
- Adjusted Intensity buttons to be up/down arrows instead of left/right arrows.
@MattWTriCoach we just released an update that allows you to stay in a Ramp Test even if you donāt have power connected and click āend testā.
- Can we get a full list of the shortcuts?
None seem listed in the current support site:
Just been kicked out of group workouts when you pushed the update.
Here is a list of the new and updated shortcuts, they can be found under Settings in the desktop apps. We are working on adjusting that article now, so thanks for mentioning it! ![]()
Iām getting an error message āan update is required to access this featureā when trying to enter a group workout but I have not gotten the āupdate is availableā at the top of the screen.
The banner doesnāt appear until the latest version has finished downloading in the background. It should appear soon, but you can always download the latest version directly here.
Thanks I was being impatient. It finally popped up
A couple of other new things:
- Workout name now shown (albeit kind of small and crammed in).
- Projected end time of the workout (interesting as a request for total workout time remaining was mentioned just yesterday).
Projected end time is such a nice little QOL improvement ![]()
I donāt have a date, but youāll see the iOS app updated then weāll get group workouts on it. Itās a major project for us and pretty close.
Rode the updated app today with a few pals, perhaps they can chime in too (@paulgrav @Mark0930)
- Logging early (10mins or so) and had the same issue that could not see anyone else, had to log out and back in again to see the others.
- Sound: when I activated my mic (pressing m) it cut the audio each time so could not have both - this was the default behaviour when I logged into the workout, and was restored when I muted. This also happened when I lost all video to the other guys and stayed that way when it came back on.
- To get the audio and mic to work had to go into settings for the audio and mic, select another device and reselect the one I needed (my BT headset), then it worked.
- During the workout when looking at the other chaps the embedded videos showed, in the last 1 hour, their cadence and HR as a stuck value.
- the cog on the video for the others is not so obvious what it would have in that menu. I think it is also too easy to click āreport athleteā, would argue that should be a separate button to press, maybe an exclamation mark or something
Workout is there for TR to check if they want to (todayās date, elephants +5, user admigo).
(sorry for the lengthy list, I partly work in product management :P)
HTH!
@Nate_Pearson
Thanks @admigo! Weāll take a look at your ride this morning to see what we can find in the logs.
Did my first TR group workout today. Worked seamlessly and enjoyed it; 4yrs of training on my own and I may be a convert.
@bnied please pass my thanks on the the TR Team ![]()
@bnied @Nate_Pearson @Jonathan Just a fyi i scheduled whorl tomorrow for outdoor and it changed the name, time and tss. All good for me as I was going to ride 1:30 anyway but figured I would let you know. Screenshots before and after.
Need also to update the description from 4 to 10ā¦
Did Spanish needle today. Loved it, but the group workouts since the last update has broken my installation tbh and is adding on about 5-10min debugging per workout. The video drops at least twice per workout, and then tries to reconnect. After a few failed attempts it will not do so anymore. At that point I have to quit and rejoin, which then splits up my workouts. I check my connection using fast.de and albeit not always super fast I would expect it to work out (slow for me is about 10mb down). Every time I log in to the others in the group say they cannot see my video even though I have it active and I can see my own plus everyone else. Bit of a weird bug.
Also, the fact that when I activate my mic it mutes the audio and I have to reselect the audio output again (essentially refresh it) has to be done each time the video cuts out is something I neednāt do before so that has changed as well.
Looking forward to the next update ![]()
