Thanks as always @mcneese.chad
I have the group calendar added and can view it in my web browser but it is not showing up on my mobile. Anyone able to get it mobile as well? I have an iPhone.
Iāve found similar on my iPhone. I canāt see it in the iOS calendar app where I do see my personal Google calendar.
Using the Google Calendar iOS app I can see this shared calendar.
I tried subscribing to the shared calendar with normal iOS calendar subscription steps, but itās failing currently.
This happened to me yesterday and tried to add via IOS. I end up going on my computer and added it there no problem. When I re-logged back into IOS it showed up.
Chad, what if the host drops out and the guest who is not doing the workout gets subbed?
Same. I donāt even see the group calendar as an option when I go into settings so I tried manually adding the calendar and no luck that way either. I will download the google calendar app and see if that works!
So many new things to learn here. Iāve asked @ ericallenboyd to join a ride, which seems a good opportunity to figure out the Group feature as well as meet a few new folks.
Yes join for sure. Will boot up in an hour and see you there
Speculating:
- In the current state, all GW riders have the same workout loaded. Assuming the host hit play (or even if not?)
- Everyone that is following the actual workout like normal will still be following it, and one of those following it will inherit the new host duties, with play/pause control.
- Anyone that is using my hack, will still be following the GW version with no devices connected, and their 2nd device will still be running their hacked workout. If they happen to inherit host control, I donāt think that will cause any problem either.
Essentially, I think nothing much changes, other than the person who can now play/pause the workout.
I just logged into the workout and it is setup just in case you login and do not see me. I am not down in the basement yet but will go down there in 20 minutes or so or 5-10 minutes before the start.
edit: @MGS @GregElwell
We are live. 2 more can join if needed. @Nate_Pearson
I“m lost. Anyone is going to make a detailed tutorial on how to follow group rides shared links?
Its on the google shared calendar. Instructions:
https://docs.google.com/document/u/0/d/13AQVSXOa2iRGVe1x22XeF2WYqzbaOWy5wQv4XR48_JI/mobilebasic
Full info is in the OP at the top.
Let us know of any specific questions once you review and follow those.
All clear but I wonder when 1.000+ people will use thisā¦
This is not meant to be a perfect or long-term solution. I am hopeful that TR will make an integrated solution. But they did the minimum to get us the pure function, and we will make this work until they or someone else comes up with a better solution.
This is a bug. Try restarting the app. We have engineers trying to fix it now. Basically youāre not getting a good connection to the server.
If thereās space left in Carter tonight Iāll jump in. I show 4 Yes and 1 maybe.
Just sent a message to the one pending and he is planning to attend (Barrett), so looks like Iām full.
