Garmin Training Status now populates for TrainerRoad workouts
So do I, but have the issue.
Anyone tried the workout on Garmin’s Tacx trainer?
Yes I ride a Neo 2T with FR955 (not recording with the watch). Direct sync to Garmin Connect from TR. And have turned off my 1040 since hearing from @dcrainmaker. What is your question?
If you have the recovery time?
@libreus, the trainer does not affect recovery time. It would be the trainerroad workout data feeding Garmin Connect and then a more recent Garmin device set as “primary training device” in settings and then having the device calculate the training impact.
In my case, through advice here from Ray, I am no longer dual recording my rides on my Edge 1040. I have TR feeding Connect, and my Garmin Forerunner 955 (which is only used as a watch during rides) is handling the calculations. And yes, then training impact is properly calculated with recovery time being impacted.
As of yesterday (with Rouvy), the recovery time after the workout showed again in Garming Connect and the Training Status works as well … what happened in the time between, who knows … :man_shrugging:
Hi, any news for recovery time update for TR app? Does it work?
I can confirm that now it is working recovery time also for TR app…
I fixed this by turning on Physio TrueUp, which hadn’t been needed before with my setup for some reason.
I have a question though: If I record on a ride on my Garmin 810 will that work when it comes through to my watch (Forerunner)? I swear it used to work last year, but last time I tried it a couple of weeks ago nothing happened (even with trueup on). It sounds from above like there has been some issues with the metrics Garmin-side so could be that? This mainly affects me for outdoor rides (with PM as I can’t link my PM to my Forerunner - I record MTB rides sans PM directly on the watch) and Zwift races where I am not dual running TR (I usually dual run TR with Zwift for workouts).
I know you should be able to link Zwift directly to Garmin but my ecosystem at the moment has Zwift > Strava and TR > Garmin, so I don’t really want to link Zwift to TR as well cos I kept getting duplicates going to Strava when I had this before.
I could also record the Zwift racing using Free Ride in TR (basically use the TR app as a head unit) - otherwise the data won’t make it into TR for AI FTP unless I manually upload it there.
Agreed. I tested a bunch early last week, then again today, it’s working properly now.
Note that if you have a watch/etc, it will need to complete a sync back to whatever the primary training device is, before it updates across the board.
Hi all, sorry to resurrect this thread.
I’m having some issues with TR indoor workouts populating my Garmin metrics. Not anything advanced - it’s not even updating exercise load.
My setup is pretty basic. I have an Edge 840 and no other Garmin devices. All outdoor rides are recorded on the Edge, and all indoor rides are recorded w/ TR only. I am not dual recording.
I’ve made sure to do the double sync (GC->Edge->back). The indoor workouts are showing up on GC as expected, but none of the load metrics are showing up. They don’t appear on the device or in GC, but I can see the rides on both.
I only got my Edge 10 days ago so none of the more advanced stats are populated yet, but I expected TR workouts to modify my exercise load.
Some pics:
The last ride on my training load page is an outdoor ride from June 1.
My activities page shows the TR workout from this morning.
And the TR workout has all of the power/HR/cadence stats I would expect.
What I’ve tried:
  • reauthorizing TR/GC
  • resyncing all devices
  • verified Physio TrueUp is active (but it’s my only device, so…)
Versions:
  • GC app 5.10.21
  • Edge 840 firmware 21.17
Anything I’ve missed?
Thanks in advance!
I am new to Garmin (Forerunner 265S) and would really appreciate updates from anyone who knows what’s up. My TR indoor rides, which I do with a chest strap and without dual recording, show up in my Activities list in the Garmin Connect app, but not in the Exercise Load screen (which apparently only shows activities recorded on the watch, per the dates of activities listed on this screen) and probably not in the Load Focus screen (I don’t see dates here but the balance seems off). It didn’t occur to me in buying the watch that I would need to dual record to get such information. Do I need to dual-record, or is something off with my syncing/connecions somehow? I am fine with syncing a few times and waiting a while, but that doesn’t help.
Also, I did an indoor VO2 max ride but didn’t get a VO2 max score, and I’m not sure I would ever do such a ride outdoors on crowded trails. Is it really not possible for Garmin to calculate this figure for me based on the chest strap/indoor data?
I use the FitFilesTool site to change TR workouts to look like they’re from my Garmin. Easier for me than dual recording. Download the fit file, upload to the fitfiletool site and upload the resulting file to Garmin and delete the TR version.
https://www.fitfiletools.com/#/changer%23view
Argh. Thanks for the update, not what I was hoping to hear, but at least I have clarity!
Huh. That has some appeal to me over dual-recording, because the HR that the Forerunner records is WAY off (like 60% of actual chest strap data), so I’d rather trick the Garmin into thinking it recorded the TR file. Thanks very much for the link!
p.s. Just venting into the void: my old Fitbit Charge 5, while crappily constructed, always reported HR data very close to what the chest strap was getting. I am totally baffled by how bad the Garmin is at this and worried about not hearing back from them after 2 days!
Not sure if matters, but just looked up my workout today in Garmin Connect. It was a v02 max (cape range) that I rated very hard on TR. Garmin says it was a recovery ride lol. I’m guessing because the avg HR? That’s kind of weak if that’s all it looks at.
No, and in my experience it does a really good job determining training effect. Ride after ride after ride after ride (for years and years).
Using it requires some initial setup, and then on two devices (530 and 84)) it does a really good job identifying training effect for 2 of the 3 energy systems (Aerobic and Glycolytic/Anaerobic). And then maps to primary benefit:
Not sure what happened in your case. Most of mine are pretty darn accurate, with or without a workout loaded.
For example below is a super short & easy HOT ride, temperature was 100-102F / 38-39C. No workout loaded.
Riding easy, turned out to be around 35% FTP. For some training stimulus, I tossed in some hard (not max) roughly 30-sec sprints to work on re-calibrating my pacing.
Average HR of 127bpm, in the upper half of Coggan zone2-HR. Easy enough HR that I can talk your ear off without having to stop and take breaths.
Garmin zones report:
and training effect:
Just a note if you’re like me and don’t want to have to dual record or go into files and modify them yourself. I use the RunGap app with the “Swag Bag” add-on. I think it costs $10yr? My workout player sends the post-workout file to RunGap, which then sends the workout to Garmin as if it were a Garmin workout, so you get the breakdown.
How bizarre. It’s like it’s pouting that it’s not being used. I wasn’t expecting this kind of issue, given that the Fitbits kept up fine without starting an activity.
Thanks, I will look into that.
