As the title says: I want to correctly tag gear in Garmin Connect, so is there anyway to bulk edit workouts to update the Gear (bike) associated with multiple rides at one time? Doing this one ride at a time will be very time consuming
Unfortunately I don’t know of a way to do it for already recorded rides. You can add a new piece of gear and make it the default for “Cycling” and you can GC the first use date and it will ask you to update all cycling rides to include that default piece of gear. However if your’re trying to mass edit different rides to different bikes with different pieces of gear GC doesn’t have a way of doing that. For what it’s worth GC now allows you to create gear collections and you can assign those to default activity types. For example if I record a MTB ride it will automatically add my MTB gear to the ride. Sorry it doesn’t help you mass edit past rides.
