I started a year long plan builder plan in October selecting mid volume rolling race. I have no particular races or events (at this point) I am trying to peak for. So currently the cycle looks like:
Base-Build-Specialty-Base-Build-Specialty
With the specialty due for some point in early February. I would like to change the cycle to look more something like:
Base-Build-Base-Build-Specialty
I believe the current workaround is to delete the plan builder plan and build a new predating to my original plan start date.
I just wish there was a way to change the block phase in the same means I can edit the block type within a plan (e.g change a base block from sweet spot to polarized or traditional).
Hey there @patricksudol!
Our team has some ideas for Plan Builder and the Calendar – I’ll be sure to pass this suggestion along.
As a workaround, you could manually add each training phase to your Calendar individually. That way, you could get your phases lined up as you’d like them to. As long as you have Adaptive Training enabled, you would still get suggested adaptations as you work through your plan, dialing in each workout for your fitness levels.
We appreciate the feedback! Feel free to let me know if you have any other questions.
Look forward to them!
I assume that involves deleting my current plan?
Yes, that’s correct – you’d have to delete the current plan so as to clear up space to add the phases individually.
