ITS TOO LATE I’VE RESPONDED
Its okay, another athlete may have the same question and stumble across this thread instead of the announcement. Not a bad thing!
Been using the beta (now public) version for about a week now.
On a Tacx Neo 2T trainer, used in ERG mode all the time.
One thing I noticed is that on the old app, power increases for intervals started a couple of seconds before. Let’s say on a VO2Max workout, when going from 120 to 360 watts, the power ramped-up a couple of seconds before the interval (as if the power increase commands were sent a couple of seconds in advace). Now it only ramps up at the exact start of the interval. Doesn’t actually change much overall (it starts tailing off a couple of seconds later also), it’s just kind of messing with my brain since I’ve gotten used to the old behavior ![]()
Is this a setting of sorts, or something actually changed in the way it works?
It is what I experienced and commented on some months ago. I stopped using the beta for short intervals as it was more a mental issue as the firs t few seconds were never at power. I haven’t tried the current version yet with this type of workout
This is totally screwing with me, too! I’m like a conditioned dog and when I hear that second countdown beep I’m ready for the ramp to start and now it’s not starting until the fourth (last) beep. Same thing at the end, as you say. I’m sure it will feel normal in a week, but today was hilarious.
Having an issue with planning a specific workout.
I can reproduce the problem:
In my calender select hawk mountain +2, edit it and switch it to outside. It instantly crashes.
Also if I try to plan it via workouts - hawk mountain +2 and select the outside option, it crashes.
I’m in IOS beta latest version 2021.11.1 (91969).
@Pete I’ve changed the workout to the outside version on de website and now I can’t even start the TR app.
Switched it back to inside and everything works again.
App Version: 2021.12.0.91970
the MOST annoying bug has started to appear. I use TR on my iPhone 11 Pro, whilst using Spotify in the background connected via AirPods.
Never happened before now, but every time the workout makes a noise, this could be introduction of text on screen, a start or stopping of an interval…any noise from the app whilst doing a workout.
Pauses my headphones, stopping my music. If i didnt have an Apple watch, id have to leave TR and go into Spotify / Apple Music - restart my tunes only to have them paused again on the next interaction within the TR app.
Please fix this…![]()
We had another recent report of this and it sounds like it was resolved after updating iOS to the latest version. Would you mind checking if you have an iOS update available and, if so, see if installing it resolves the issue?
Let me know either way!
Hey @Geoff I’m running latest - 14.4.2
the latest update has the app loading extremely fast. bravo. thanks for the hard work!
Does the estimate show by default or do you have to turn it on?
It’s in the data page that you can see normally by swiping the middle of the screen to the left.
For ramp test the top left field changes to ftp estimate (for first 5-7 minutes it’s a countdown timer until the estimate will be provided then it switches to the current estimate if you stopped at that moment)
Love the new TN recommendation on the beta app. Been using TN exclusively for almost a month and really great.
SO what if we touched it? LOL---- I did but cant remember the original setting
Original it right in the middle. I think 1.0
Any update on this?
Workout pauses for no reason after about 30 minutes
Version: 2021.18.0.91976
Installed on: iPad 12.9” (2018), iOS 14.5.1
Connected devices: Quark DZero power meter, Wahoo Tickr heart rate strap
For the last three workouts my workout suddenly paused after roughly 30 minutes. I do not know if there is any significance to it, but it could be 30 minutes after my power meter has woken up. I did not experience any power meter drop outs or so, it just pauses and I have to manually continue.
Definitley get in touch with support (support@trainerroad.com) on that one. Sorry for the trouble!
email sent. Thanks for the quick response ![]()
Hi Brian! Have you got that issue fixed? I had to switch interval sounds at my last workout since music was stopping as well, so was curious if there is another way to fix it?
