One season later, AT is out of Beta, but itâs still a bitâŚwonkyâŚfor these critical race sessions.
Description of todaysâ Brick workout: In the midst of a 1hr45min bike workout, youâll sustain 90 minutes of effort between 80-85% FTP pushing you very close to the effort youâll try to hold during your race-day bike leg. Then, youâll dismount and transition quickly into your running gear right before you take off on a 60-minute run at a Easy-Moderate, RPE6 pace and grow a little more accustomed to a longer run this time around.
What actually happened: The workout was Gibraltar -2. â105 minutes of continuous riding where youâll spend 90 minutes between 75-80% FTP.â
Now, I was all ready to blame AT for this, but then I noticed that Gibraltar -2 is listed as a Breakthrough workout at 6.2, whereas Iâm at 2.8 for Tempo. Thatâs an usually large gap.
So does this mean that:
AT is now smart enough to keep away from these key sessions (to avoid the problem linked earlier!), and whoever made the training plan made a mistake.
AT adapted the key session, but for whatever reason was OK with making it a breakthrough.
In any case, for these key sessions, Iâd prefer AT not modify the difficulty away from race pace. If I canât maintain this power, or itâs way too easy, Iâd prefer to find out about this now and not in the race.
Yes this is correct, AT will schedule you âBreakthroughâ workouts from time to time. Training is meant to push you occassionaly!
As always though, specifics about your workouts, adaptations, and Progression Levels are best served to the team at support@trainerroad.com. They have visibility to the full scope of your ride logs, adaptation history, PL changes, etc. Theyâll have the most accurate advice and insight, and be able to apply any fixes if needed. Cheers.
There is absolutely nothing specific about this question. Itâs a general one: does AT adapt the race simulations / brick workouts or not? If it does, as you seem to be saying, thatâs actually undesirable, and it causes the mismatches in the descriptions of brick workouts like in the first post.
If it doesnât, itâs a simple mistake in the workout description (that I can point out to support).
Happy to clarify. Brick workouts can receive adaptations but those adaptations vary greatly in severity depending upon those aforementioned specificities within AT, and theres no general formula of âevery brick workout is be adapted in âxâ way for everyoneâ.
The why behind those adaptations, being served which workout at a level in relation to your PLs, and if/how adaptations take place during a certain week (and in your case, phase), or for a brick workout are extremely individual and require the full scope of your workout compliance.
Thank you. That means the workout text description for the brick is almost always going to be wrong though, as they refer to specific workouts (and were likely written before AT).
