Is anyone running a stages/4iii on an Aspero?
Any idea if there is enough frame clearance? Any easier options ignoring pedals?
Thanks Shane - I’m assuming that’s the road 4iii in the video, meaning if I got the GRX version, it would have an extra 2.5mm clearance compared to what you showed?
4iiii has a template you can download to see if it will fit.
I’ve got a size 51 Cervelo Aspero that I’m getting a factory install done, as the ride ready pm does not clear the chain stay.
Was going to recommend the AAA battery check.
FYI, you’d need to have a GRX 810 crankarm to mount a 4iiii PM. The GRX 600 has a hollow back and won’t take the PM. I’m trying to locate one myself but my LBS says no stock until the spring.
I put a Quarq on and it jjjuuusssttt fit.
