Big left:right imbalance
I took the plunge and did the static weight test, the good news my dual sided power meter is well within spec, the bad news is I am not: my L:R imbalance is real (generally it is 40‐43:60-57)
So any suggestions how I could address this (my saddle is already quite low… )
My L:R balance two years ago was 58:42. It’s down to 53:47 now after regularly doing single leg deadlifts and single leg squats. (Lots of variety of either to pick from.)
Once I removed the ability of the left leg to dominate, the right leg had no choice but to step up it’s game. And if you do, say, X reps with the stronger leg, you can then push your weaker leg to do the same. It’s a great mental game to get through some otherwise difficult exercises.
I didn’t change anything about my cycling or really ever think about it while riding a bike.
A L/R imbalance is not a problem is a symptom. So I don’t agree with just doing single legs exercises until your left leg get stronger, I do agree with looking for a bike fitter or specialist so you can find the real problem.
Is there is no problem to solve, may be you don’t need to even worry about the imbalance. (But I insist on looking for a problem first, because it’s actually a significant imbalance)
When I look at rides 2 years ago I started with a minor (normal) imbalance of 47-45/53-55 but that imbalance gradually became worse and seems to be more prominent when taking it easy.
I think that sort of rules out a leg length discrepancy. I think the discrepancy started to increase after a fall on the knee of my stronger right leg
My left right discrepancy started to increase after I was banned from going to gyms (etc) and started doing single legged exercises at home instead (which was around the same time I fell on my good leg as I wrote in the post above)
My leg imbalance differs. On outside rides it’s 47/53 - 48/52. On trainer rides it’s 45/55. I figure it has something to do with the Bike being fixed but I have no idea
In that case I’m afraid to look at my inside data. Trainerroad doesn’t record L/R data so all my data is from outside
Simultaneously run your bike computer while on your trainer. Power meter power goes to bike computer trainer power goes to trainerroad. Then compare
I haven’t done that since December but that data doesn’t look good (40/60%) and my discrepancy on my normal bike got bigger since then
I tried pedaling with one foot on an indoor treadmill to strengthen my legs. You can warm up in 15-20 minutes when pedaling with both feet. Then I removed my strong pivot leg and hooked it over the treadmill near where it connected to the rear wheel. Or, you can place it on a chair or stool next to it. I found this set of exercises quite helpful and I have improved a bit. I found this exercise quite useful and I have improved a bit through it.
