BestBikesplit Question
Has anyone ever tried having BestBikesplit file loaded on your Garmin and at the same riding indoor?
What I am trying to achieve is, I have a upcoming TT and I want load BBS file on my Garmin device. But at the same time I want Garmin to control the resistance of the course.
Thanks
Doesn’t directly answer your question but did load it into WorkoutCreator so could then run a BBS ā€˜profile’ in TR app. Maybe you could then push as an outside ride to work it directly from your Garmin head unit
Custom workouts from the TR Workout Creator are not supported for ā€œoutsideā€ workouts right now.
I am no Garmin expert, but I think you may need to do the two items (workout and BBS) on separate devices.
I’d probably look at the profile BBS gives you and re-create that with the TR workout creator (or TP or GC or your trainer’s app). Then load either the custom TR workout, or push the file to your Garmin, if made with another program.
Thanks for the responses. I will try and feedback.
Thanks
Doesn’t BBS use your GPS location to determine what power you should be pushing where on a given course? It has been awhile since I used a BBS file on course, so perhaps they have changed that, but that was my recollection.
In which case, you couldn’t use the BBS file on your trainer anyway. As suggested ^^, you should probably just recreate the file in TR.
