Hi there… Few days ago i bought my first trainer (Elite Direto X), coming from my Kinetic Road Machine (also upgraded with ProFlyweel), which i was using with Favero Assioma Pedals using Sunto ANT+ Stick and connected to MacMini. Sometimes stick was not found, but simple unplug and plug again will solve the problem.
Now i realized that i have strange problem with my DiretoX connection (still did not try with Trainer Road), but i can see that problem with Elite MyTraining application and also ZWIFT.
When i use ANT+ Connection to connect to trainer using Elite application, i can find it, also i can connect to cadence sensor or HR strap. But when i try to adjust Power Smoothing nothing… It’s just closing… When i try the same with Bluetooth connection all fine. Seem that even can connect trough ANT+ it dont work properly
ZWIFT When im connected on trainer trough ANT FE-C i can find the trainer, but trying ERG mode workout dont work properly at all… Also in sim mode it’s not ideal. So same here… Even is connected trough ANT+ something is wrong and not work properly…
When i connect using Bluetooth everything fine (will test tommorow more detailed, i tried now just few miutes for a test, tired for proper test)
I also tried using USB extender (usb 2.0 1.8 and powered up usb 3.0 extender which i put it just few cm’s under trainer). Nothing changed.
I tried same ant+ stick on PC and Windows 7.Just Elite MyEtraining app, connected to trainer without problem, and done Power Smoothing without problem. I tried from Elite MyEtraining app Training test and can feel how trainer adjust the power. So working ok from the short test i done
Anyone else have ANT+ issues on Mac Os? (latest MacOs installed, and i use MacMini late 2012 model)
Still did not tried Trainer Road since i want to start in about 10 daysto be able to ride the workouts without missing so dont want to activate right now
