AI FTP not changing when it should
The vast majority of my riding is outdoors, tracked using a Wahoo Elemnt and synced directly to TR (not via Strava).
I’ve noticed that the AI FTP reported each month is suspiciously static and is reporting an identical FTP month on month.
The reason I’m sceptical: I noticed a drop in form during the summer - not massive, but enough to mean my 20min TT effort was no longer sustainable. TR has, in past years, picked up on this.
Has something changed? Now that we’re entering Autumn/Winter I’ll be getting more time on the turbo, which may fix it - but I expect my zones will be out for a while.
The AI FTP has always seemed to be close enough that I could use it as a gauge.
I would suggest chatting or emailing support, they will check your account and let you know what they see.
@Caro.Gomez-Villafane and @eddie are on here frequently, but you would get to the root cause faster thought support.
I’ve taken a quick look, and while I do see a few redundant FTP entries, I don’t see anything glaring that makes me think they weren’t accurate.
It looks like you’re due for an FTP detection next week. Could you let me know what you’re given then?
Thanks for taking a look. I’ll check back next week :+1:
Just tested. The value has changed fractionally (which is what I’d expect in the base season). Looks like everything is working as normal.
Great to hear!
Just shout if I can help out with anything down the road. :handshake:
