Onboarding reduced AI FTP by 35%!
I recently restarted my TrainerRoad subscription after letting it lapse for a week as I was on holiday.
When I logged into app I did an AI check FTP and it gave a small reduction as expected as I’ve done no training for a week 280 down to 274.
Though after renewal of my subscription I couldn’t get the app to create a plan for me so I decided to use the web version. At this point the web wanted me to onboard so I went through the process - same connections same data, though onboarding gave me a FTP of 192!
Upside was I could no create a plan, downside was the weird ftp. Only way I found to remove it was delete it from my history.
Try the FTP test, which ever one you’re most comfortable with.
Same happened to me, took the ramp test and had a 20 watt difference from on boarding.
Yeah I did a test, I was just surprised that after taking 1 week off from training and letting my subscription lapse for that 1 week, app and web ftp numbers differ so much -35% is pretty extreme!
You could try asking support@trainerroad.com as we would just be guessing.
I agree, my FTP was 230 I took a week holiday and when I got back my AIFTP dropped to 214, this put me back to January numbers, it didn’t make since to me.
I had a similar issue. The last few weeks I have not done as much focused workouts since I had longer gravel races both weekends. I am starting a new build so wanted to set my zones correctly. I did an AI FTP detection last Tuesday and it dropped from 320-316 which I thought was inaccurate based on how I have been riding and feeling. To check I did both a 2x8 FTP Test and 20 Minute FTP test last week after the questioning. My 2x8 I averaged 368 for both intervals which at 90% would set my FTP at 331. The twenty minute test didn’t go as well as I wasn’t fully rested but I did average 346, or 95% would set my FTP at 329.
I ended up manually adjusting my FTP to the lower one at 329. Crazy as I was guessing my FTP was likely around 330. I think the moral of the story is still doing testing (especially the 20 minute which I hate) is probably good to do periodically to verify numbers.
