I decided to peek. And will have little regret if I decide to bump intensity down 3% in the moment.
today was the first time in forever where I really attempted a long threshold interval. I was a bit time crunched so I aimed for 35mins. So while I’ve had access to AIFTP since the early release last Feb, I haven’t adjusted my ftp at all, and it’s been set at 295, my AI FTP readings are generally around +/- 5w and my most recent predictor is 299.
Anyhow, I did my workout in zwift on sim mode, and only watching 3sec power, so I wasn’t super influenced by averages. for 35min I avg 295 and I’d say it felt about right at that edge of doable/hard. I can pretty confidently say I prob could have easily done 5 additional min, and probably at 45min I’d really be feeling it, so I think my personal estimate has been spot on. Def not feeling (at the moment) that I’d want to push my luck up to 300. But I’m also at the tail end of a block and not super fresh so who knows if in a couple of weeks I’ll change my mind!
Not a lot of comments but it’s looking like there’s some people who are finding it very accurate and some people who are not. Would be nice to know if there’s something skewing it one way or the other.
What do you mean by this? Are you using Xert’s prediction and then using it for your TR workouts? Are you doing a specific workout to see how the FTP feels? Or something else altogether?
I look at the Xert FTP prediction then I do an FTP test and the two numbers match. I’ve done ramp tests in Zwift Sufferfest and also the Sufferfest 4D test, they all match what Xert predicts.
A couple of thoughts then: Each test/prediction you listed requires maximal efforts (as far as I know, at least). TR’s doesn’t. If you are like me and struggle with max efforts, it could be that all of them are low.
I once did so poorly on a ramp test it would have had me doing sweet spot intervals at 193 watts when I was doing 3-4 hour endurance rides at 200 watts. this was before AI FTP so unfortunately I don’t know what it would predicted me at.
My current AI FTP from today was 279. I am almost positive I wouldn’t get that from a ramp test. I would guess I’d test at 250-260. However, I just scheduled a tempo workout with PL 7.1 that looks easy at my AI FTP . Which brings me to this quote.
For me, this rings true. It definitely sets my zones better than the ramp test.
That said, you could absolutely be right and be in the ~6% that would “struggle” in subsequent workouts using the AI FTP. It might also be worth trying some workouts at the AI FTP to see how it feels.
I’m unclear what the consensus is here. It sounds like @voldemort is essentially saying that the aiFTP is the correct FTP and the others are wrong. Is that a good summary? If it is, I’m not totally opposed to that idea but as mentioned by @wintermute I’m not sure how to evaluate that. You are just suggesting to try some workouts? Would you think that the aiFTP is transportable to another service (like zwift)?
@wintermute it sounds to me like you are saying that your aiFTP seems more accurate than a ramp test. Am I correct?
To me that sounds like you think the aiFTP is a bit lower but better for it. That’s great but mine is 30 watts higher with aiFTP. I can’t imagine that would work well for me to use as interval targets.
dumb response that is both toxic and misses the point.
My confirmation bias would be it’s great to go around saying my FTP is 30 watts higher. It kind of looks like I can even do the workouts. That said, when multiple other sources say one thing and TR is the outlier, I have a hard time believing that. I suspect there’s something happenning where it’s not that accurate for some types of riders.
Does anybody know if the AI FTP is influenced by survey responses? These are obviously quite subjective, but I could see how some systems might use the indicator that a tough workout has been ‘surveyed’ as easy and concluded that the FTP should go up a notch.
Just keen to get on top of understanding how trustworthy I can consider the AI to be or I should run a more traditional FTP test in parallel (hopefully no need!).
As I understand it it does take in survey responses, at least for TR workouts. I can only say n=1 that AI FTP and PL’s seem to be working ok for me, following TR plans (which is the most important thing for me, paying my sub to TR!)
Rather than do a test, you could sub in Lamarck which would give some indication.
Good to know and thank you.
I’ve been doing the Kolie Moore progression test but might just see how I fare with the plan following the AI hike. I don’t really care what my FTP number is, as long as my training is at the right level.
Pre AI FTP I was using the KM test or self selecting, as I really underperformed on the ramp test. Like you, I’m not really bothered once it’s working for the training, which I find hard to see how it doesn’t with AT (and honest survey answers!).
Going from base to build I did an AI FTP detection 2,5 weeks ago. The result was 1W off where I was standing so I did not accept any changes.
I have recently been sick, and used the Illnessannotation in the calendar. After extending the ilness for more and more days the AI suddenly promted a Ramp test/AI FTP detection. That seemed reasonable, seeing that I haven been doing any training for the last 10 days.
When trying to do a detection (web) I get * Your Recent AI FTP Detection is Still Available* and been told that I can use it again in 10 days and some.
The 28 day window is ok for normal circumstances but wouldnt this case be an obvious exception from the 28 days rule? @SarahLaverty
It is by no means important for me to get the “correct” FTP right now. I was planning to ease in with som easy wo’s and then do some more strenous ones before new test and Base 2 period in 11 days.
When the system triggers a test I would assume it should be allowed
After some time off the bike, we will schedule you a Ramp test, to ensure your training is appropriately difficult.
As such, your FTP detected a couple of weeks ago is valid and will ensure that your training continues to progress appropriately. If you accept this FTP detection result, we will replace the Ramp test with another Workout. If you feel like you’d rather an easier Workout to ease back into things, I’d suggest you use Workout Alternates to find a different Workout. Check out this article: How to use Workout Alternates.
Let us know if you have any questions about this!
Not sure about that. Didn’t Nate say something about AI FTP detection being able to down adjust during the 28 day lock in case of illness/injury? So detecting downward would be possible, just upward would be prevented.
Pretty solid, almost 4 weeks of TR workouts, and my FTP went down a watt. With that, my 6 week daily ave TSS didn’t change much during that period, and these 4 weeks were largely on the trainer, or with with HR only on endurance rides outdoors (PM is in the shop).
I would have most likely down the intensity outdoors at a lower HR and RPE, but I would have stuck to the targets, so my post workout surveys might have read easier.
I thought maybe 5 or 10 watts increase going in, but the more I think about it, that might just tip me over to incompletes in workouts on the trainer. Only my first month of TR planned stuff, so I’ll “let go and let god” and see where we go.
Quick question and apologies if answered elsewhere (couldn’t find on a search)
Does AI FTP detection take account of a workout I have completed earlier on the same day?
I’m due to ramp test / AI Test on Wednesday.
I just completed a workout (on Monday). Will it take todays workout into account if I use AI FTP detection now? Or should wait until Tuesday to hit the button or will it account
Can’t seem to find the answer elsewhere. I am doing a long distance tri plan. I have added some extra running into the plan as well so it is 3-4 Rides, 3 swims and 5 runs. In regards to AI FTP detection is it going to take into account the swims and runs? or does it totally ignore them. In theory my cardio should get a bump from those other endurance sports that will help my FTP? Maybe it’s worth still doing the ramp test in my case?
