For what it’s worth, I have Recon 2.0 and even after major surgery, still had unbearable squeaking from the shoe/pedal interface. I’m in the process of trying it with my Shimano winter boots instead.
Favero Assioma
Xpedo CXR
Recon 2.0 size 49
Favero Assioma
Xpedo CXR
Recon 2.0 size 49
They will see their service on the gravel bike not mtb…so the gravel with DuoShi is closer to a mtb with normal pedals. I’ve been using the mountain bike as the comparison test mule as it has a Power2Max. For now, they are inside on the trainer.
The fat bike test was a rugged mega q-factor setup and not one for long. That was a pedal setup test for a rider who wanted to have option of the flat/spd body and only bike I could ride at the time was the fat bike.
I am interested on hearing how Shimano went. While I also have squeaking (mainly indoor where I can actually hear it), I don’t think it is from the Shoe but the cleat. I thought about changing the cleat from the *XPEDO XPT (6° Float) to SPD cleat. Not sure if the SPD cleat will work with CXR Pedal.
I found this excerpt from the Gravel Cyclist:
Cleats
A review wouldn’t be a review unless you do something you’re not supposed to do with a product. In the case of the Xpedo CXR pedals, I tried them with the supplied Xpedo cleats and Shimano SH51 SPD cleats. For the record, Xpedo CXR pedals are Shimano SPD compatible.
Top: Xpedo CXR Cleat, Bottom: Shimano SH51 Cleat.
As expected, the CXR’s work flawlessly with Xpedo cleats. They were easy to engage and disengage.
Using the Shimano SH51 SPD cleat, the CXR’s were easy to engage, but often had a tendency to hang up at the front of the pedal during attempted disengagement. This is a point of concern. However, I figured a technique to ensure disengagement almost 100% of the time, but it is worth noting the CXR pedals work best with the Xpedo cleats.
Interesting…my squeaky Recon/CXR issue is using SPD cleats.
I’m doing my first ride with them tomorrow with CXR, Shimano shoes (instead of recon), and spd cleats. Will report back.
I use Xpedo MForce 8 pedals with shimano SH56 cleats with no issues. I like the easier multi-sided release of the SH56.
Anyone attempt the hack with Time pedals? I know it’s a long shot that the spindles are a match. But I’m just curious, as a Time Atac user.
Hi all! Anyone tried the Quoc Gran Tourer shoes on the M-Force 8 body to see if the shoes need to be trimmed?
Just bought a DuoShi kit. Thanks to this thread, I now know that the m520 is one option for dual-sided SPD cleats.
I have a set of m8000s – any knowledge of if those might be compatible, or the newer m8100?
Are 520s compatible with the duo shi? I don’t remember seeing that. If they are, that’s fantastic value.
Yes they are. Took me 30 minutes to install (because I was watching The Office at the same time
Super easy, but is it accurate? Mine were way off so I reverted back.
Well, first I installed it on my road bike because it has a Power2Max installed. Then I did a short ride and used the DC Rainmaker tool. It showed almost the same graph for both power meters.
Based on those results I moved the pedals to my MTB bike, confident that it is accurate.
On both installations I followed the instructions to the letter, including some intense pedalling with calibration before and after.
If one was to buy the shi version then do a mtb pedal conversion that would mean you get even greater q factor right?
Pardon for not reading through the 600+ posts, but can anyone tell me if I can take a spindle from the M Force 4 pedal and put it into the Thrust 8 CR pedal? Both are three bearing pedals.
If so I can move the Assioma to my M Force, then swap the M Force Ti spindle to the Thrust and have a Thrust Ti road pedal and a Gravel PM pedal.
Thanks
I run my stock Assiomas on the mountain bike, and use road shoes. Is there any reason why that is not a good idea, and why do people want to use SPD?
I bought the assioma shi and shimano spd m520 pedals but of course no one has the stupid little plastic tool to undo the spindles in the mtb pedals so hopefully I can get them out without that. Can’t wait to try them on my gravel bike.
I wish I could use them with my xt trail pedals
Amazon!
Rocks, mud, water, sand, just to name a few. When you bail on a difficult and slippery rock section, or have to hike the bike through mud or sand, or across a running stream, road cleats are SLIPPERY and road shoes are very stiff. You’re also going to have a very hard time clipping in/out with a road pedal that’s caked in mud or sand. I would flip that question and ask why you would run road shoes/pedals?
